Glow plugs on 7265??
   / Glow plugs on 7265?? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I just purchasd a used 7265 with 3 cyl. diesel engine. Glow plug lamp flashes on intermittdenty even after engine is warm. I looked in operators manual and it appears that glow plugs should operate from key switch but this one has a push-button above key swich to activate plugs. Thanks for any help,Jim
   / Glow plugs on 7265?? #2
Jim it sounds like your glowplug controller is bad. part no. MA31A66-05100
When they go bad it isn't long before they burn the glow plugs out.
Ned,is this tractor supposed to have a push button to activate GP's? If so how does the GP controller work in conjunction with push button? Thanks,Jim
   / Glow plugs on 7265?? #4
Jim someone must have added the push button switch on to activate the GP's longer. When that light is on your getting juice to the GP's.
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
11ft S/A Fuel Tank Trailer Frame (A51692)
11ft S/A Fuel Tank...
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
