glow plugs on 2305
   / glow plugs on 2305 #1
woodsleeboy
ontario, canada
anyone have some guidence on how the glow plugs work? I'm used to a light that goes out when they are ready. Is it just something that you have to time yourself?
   / glow plugs on 2305 #2
woodsleeboy,
I don't know why Deere doesn't detail this in their owner's manuals, but all you have to do is: put the tractor in gear or engage the PTO, turn the key all the way to the start position, you will hear a click and the idiot lights will dim. Just hold that for 2-20 seconds depending on the temp, put the tractor in neutral or disengage the PTO, and start er' up. /forums/images/graemlins/tongue.gif
thanks....( they didn't deliver a manual with my tractor, I have to go back to the dealer to get it so I'm going at this blind on a few things ) thanks again
   / glow plugs on 2305 #4
This might be a silly question but would it do the same thing if you just turned the key to on (glow light comes on) and wait 2-20 seconds then start. Why do you have to shift to gear or engage PTO?
Sorry, but I'm also used to the glow light that shuts off when they are warm enough.
Thanks...
   / glow plugs on 2305 #5
Nope. These tractors don't have a glow plug, but a pre-heater. You need to engage it the way I described.
   / glow plugs on 2305 #6
We get this all the time from new owners.
I suspect the 2305 is like my 4010. The glow plug position on the ignition switch is between the "on" and "start" position. However, without a test light connected to one glow plug with the other end to ground, it's very difficult to tell when you're at that "glow plug on" spot. So, the easiest way is to put the shift lever in gear and to turn the key all the way to "start" and hold for 2-5 seconds (doubt you need any longer than 5 seconds; only 2 in hot weather). Put the shift lever into "N" while still holding the key, and the engine should start instantly. This works also with the PTO button on and then off.
Get yourself a test light and check it out.
In really cold weather, be sure and move the throttle lever open about 1/3 way. Otherwise, it'll likely start and die; start and die.
Ralph
   / glow plugs on 2305 #7
JD,
On my 2305 I just jump on and turn the key wait a moment and I hear a click and my idiot lights get just a bit brighter, no engaging anything!
   / glow plugs on 2305 #8
</font><font color="blue" class="small">( On my 2305 I just jump on and turn the key wait a moment and I hear a click and my idiot lights get just a bit brighter, no engaging anything! )</font>
Yes. That's how it works, but if you want the plugs to glow longer than the standard time (if it's really cold, say) then you can use this technique to force them to stay on for a while.
Cliff
   / glow plugs on 2305 #9
</font><font color="blue" class="small">( In really cold weather, be sure and move the throttle lever open about 1/3 way. Otherwise, it'll likely start and die; start and die.
Ralph )</font>
Really Ralph, I've never had to start my 2210 at anything other than idle? /forums/images/graemlins/confused.gif
   / glow plugs on 2305 #10
I looked at the manual on the web, and it does have glow plugs. But I found on my 4110, its hard to hear the click when they go off. But like has been said, if you watch the dash lights they are dim, then in 2 or 3 seconds they get bright, that is when the glow plugs have turned off as they have heated. I know mine doesn't seem to start as quick as I would like, as a tractor with a lot more hours did. So if its cold use the in gear or PTO on for a very few seconds, and it will start faster, as they will have been on longer. I think I have figured it out. These are new and not broke in, so they don't have the compression to heat up from the pressure in there. As the rings get seated it will have more compression and will start easier. Then the few seconds of glow plug heat will be enough to start it good, unless its really cold, then of course you will probably need to use the longer way.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2011 TIGERCAT 234 KNUCKLE BOOM LOADER (A51242)
2011 TIGERCAT 234...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
Land Honor Rock Bucket (A50514)
Land Honor Rock...
Fire Truck (A51692)
Fire Truck (A51692)
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
