Glow Plugs not working.
   / Glow Plugs not working. #21
I guess reading what I had written it would sound like I turned it to the run side of the switch. I did not, I turned it counterclockwise to the glow plug side. That's when I check for voltage and I did not have anything on G1 or G2 to ground.
You know, if everything else was working correctly and can't find a switch or it's crazy expensive, then a nice toggle switch a piece of wire and a fuse, and Bob's your uncle personally I would use a momentary toggle and simply hold it for 15 or 20 seconds Let It Go, Start your engine. Fwiw...
BTW - if you do modify, could you please make a couple notes draw a short little diagram, folded nicely put in a nice Ziploc bag, attached to wiring harness. Karma will thank you
I might go with the heavy duty push button if I have a hard time finding a switch. I'm sure the switch is going to be around $100.00. I kinda would like to keep things original and I also would like the glow light to work. Down the road I might sell it and get one with at least 25hp. If not 30hp.
Thanks for all the help and suggestions.
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
1986 Ford LNT9000 Dump Truck (A56436)
1986 Ford LNT9000...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2003 Big Tex 10PI...
2005 Ford F-450 Pickup Truck, VIN # 1FDXF46P65EB16866 (A57453)
2005 Ford F-450...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
