Glow plug?
/ Glow plug? #1
fastback88
Bronze Member
Sturgeon Bay WI
Kubota L4200gtsc,LA680 loader
I have a Kubota l4200 with about 1000hrs I was wondering how you now when the glow plugs are bad? it doesn't start like it used to when its cold I have to cycle the glow plugs 3 or 4 times then it will start rite up. The glow plug light stays on for about 7 to ten sec each time. I used to just wait for the light to go out once and it would fire right up!
/ Glow plug? #2
I have the same tractor... with a few hundred more hours.
When it is under 32f degrees I will cycle the glow plugs twice, when it's below 20f I will go 3 cycles... It will fire up below 0 degrees f with 3 cycles... you can measure the resistance of each glow plug, (have to remove the common bus bar rail) they should all measure about the same. They generally go to an Open when they are bad...
/ Glow plug? #4
They will usually measure about .5 ohms or just a little under. That is hard for some ohmmeters to resolve. It may look like a short, but there is a little resistance. With 3 or 4 glow plugs in parallel when they are all connected to the buss they would look like a dead short. The engine block itself is the other conductor, the "ground side". As noted above, most would probably fail open. However many other things can cause the problem of no glow plug heating besides the glow plugs. The glow plug relay, glow plug timer circuitry, fuses, and or wiring/continuity problems. The first thing to do is to measure for voltage on the glow plug buss, and then work forward or backward depending on what you find. Another way to determine if a glow plug was working would be with an infrared hand held thermometer.
James K0UA
/ Glow plug? #5
I thank you, too. This is my first tractor and my first winter. Lots of good info on this thread.
UNUSED JCT 72" HYD ANGLE BROOM (A62131)
UNUSED JCT 72" HYD...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 23' LONG (A62131)
(2) BUNDLE OF MISC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
