Glow Plug Voltage
   / Glow Plug Voltage #1
Mahindra 2810 Massey Ferguson 1428 Case 440
Does anyone know the correct voltage that should be at the glow plug , buss bar when they are heating . My battery is at 12.6 , voltage at glow plug buss is at 10.4 . Is this correct voltage for the glow plug buss when heating ? I can’t determine in my mind why there is such a small gauge (16 or 18) wire feeding current to the glow plugs , when exiting the relay is the power wire is a 12 gauge wire . Thank you and be safe
   / Glow Plug Voltage
This is a 2810 series tractor
   / Glow Plug Voltage #3
@Death Row Dave
Not a mechanic, but that drop doesn't seem excessive considering the load that glow plugs put on a battery. If the glow plugs are doing their job for you, I would load test the battery itself to confirm it's condition, and call it good.
   / Glow Plug Voltage
Battery load test , drops to 11.9 volts . The glow plugs simply can not put that much load through a 16-18 gauge wire , it’s over a 2 bolt drop in volts . The small wire would go up in smoke at the amount of load . I’m going to have to research deeper , follow through the wiring diagram . This is really strange . If the glow plugs are designed to use 12 volts it is a simple task to wire in a new relay and direct wire to the glow plugs full 12 volts when the relay is activated .
   / Glow Plug Voltage #5
Well, you're assuming that the actual glow plugs are the only, and final current draw. Aren't there resisters in glow systems that reduce current prior to the plugs, possibly before the small gauge wire?
I have no idea, but be sure to post your conclusions !
   / Glow Plug Voltage #6
If a glow plug is working you will not measure battery voltage when they are energized.
Even if measureing voltage at the battery + and - you should see a voltage drop when they are energized.
   / Glow Plug Voltage #7
Could the smaller gauge be for the relay coil and larger 12ga wire power to glow plugs?
I'd want a wiring diagram to see where voltage drop is. If you have, say, 12.6v on one side of relay contacts, 10.4v other side then relay needs to be replaced.
Does tractor start ok regardless of 2 volt drop?
   / Glow Plug Voltage #8
Resistors in series with glow plugs to reduce the current makes little sense.
   / Glow Plug Voltage #10
Yeah that's more correct. The glow plug is a resistor same as an old school light bulb.
James
2014 Ford F-150 Pickup Truck (A49461)
2014 Ford F-150...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
