Glow Plug Timer Testing???
   / Glow Plug Timer Testing??? #1
dawii
sandra55
My glow plug indicator light (and glow plug function) no longer come on when I turn on the ignition. I checked the glow plug relay and that appears to operate fine, and the glow plugs test out fine. I suspect that the glow plug timer (LG4056/LS TRG750 - 4 pin glow timer) may be the problem, but I don't want to spend the money buying parts unless I'm sure it's the timer that's failed - how do you test the timer? No indicator as to which lead is which (three connectors on one row and one on the second row) - Tractor is a DTC300; but I think the circuits are the same on most tractors of that size.
I traced out the wires from the timer to the relay (a green & a red wire) that are on pin 1 & 3, so I assumed that if I apply 12v to pins 2 & 4, they should energize the other two for 20-30 seconds (thus opening the circuit for the glow plugs). When I tried it, I got 12v to pin 3, but no connection to pin 1 (either voltage or open circuit to any of the pins); and the power never shut off; I would assume that tells me I have a bad timer; but I'm no electronics guy - anyone confirm that this sounds right?
For any future timer testers :), I ordered a new timer and installed it - and voila, works again.
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2013 East Manufacturing 45ft T/A Walking Floor Trailer (A53422)
2013 East...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
