Glow plug light
/ Glow plug light #1
radman1
Elite Member
midwest
JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
I washed my 2002 DX29 (same as TC29D) last week and now have a glow plug problem. When the engine is cold, I can't get the glow plug light to come on and engine is harder to start. Once the engine is warm or if it has been running for awhile, I can shut off the tractor, turn the switch on and now the glow plug light will come on. Once the tractor cools off again, the glow plug doesn't work. Any ideas on the problem?
/ Glow plug light #2
The glow plug lamp timer relay probably took on water and is now acting goofy. Or some Class II key switches were weak, especially in the contact and soldered connection to the glowplug feed from the switch. Check the key switch first, then the relay. A hair dryer might cure it, but sooner or later the faulty part will need to be replaced.
/ Glow plug light
RickB
Always helpful as usual. Thanks. Where is the glow plug lamp relay located?
/ Glow plug light
I found the glow plug lamp timer relay under the right rear cover by the switch. Surprised that it actually says glow plug lamp timer right on the outside! Disconnected the key switch and relay connection and cleaned the terminals. Didn't see any water but a little dusty. Reconnected and all works normally. I usually hate most electrical problems but this was an easy fix. Thanks again RickB.
/ Glow plug light #5
A little dielectric grease on all connections will help prevent moisture problems.
/ Glow plug light
Arg! I should have done that. I even have some dielectric grease.
2016 Ford F-550 Altec AT233P 35ft Bucket Truck (A59230)
2016 Ford F-550...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2005 John Deere 7420 (A60462)
2005 John Deere...
(INOP) 2000 FORD E-350 XLT SD 11 PASSENGER VAN (A59823)
(INOP) 2000 FORD...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
9ft. EZ Loader S/A Boat Trailer (A59231)
9ft. EZ Loader S/A...
