Glow plug light will not go off
   / Glow plug light will not go off #1
2615 David
Fisherville, Ky.
Mahindra 2615 gear
Almost 11 years with my 2615 gear, it's been nearly flawless. Today this issue, when I went to start it the glow plug light wouldn't shut off. So I let it stay on what I thought would be long enough to allow it to start and then unplugged the relay and started it not feeling like leaving glow plugs energized while running was good. I believe the system has a module or controller depending on your preference for description and a relay. My guess is the timer function is part of the controller/module and for whatever reason it is getting stuck and I need to replace it. The relay only switches the power on and off to the glow plugs is also my guess. Am I on the right track? if so where's a good place to order this online? Thanks, David. :confused:
   / Glow plug light will not go off #2
Did the GP light go out when you pulled the relay?:)
Sorry for delay in reply. Busy, you know how it can go. Yes, light goes right out.
   / Glow plug light will not go off #4
Hope the relay is cheap.
1 more test.
Make sure it I the relay, and not the circuit controlling relay.
Ohm meter and some test leads to +/- will tell you.
Check contacts with field powered and not powered
   / Glow plug light will not go off #5
Let us know if you fixed it and how you did it. Thanks.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
FAKE (A52472)
FAKE (A52472)
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A52472)
MCELROY 500 SERIES...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
