Glow Plug Issue
/ Glow Plug Issue #1
hollywd75
IH 454, JD LX188
Hello,
I bought a 2004 TC30 a few months ago, the glow plugs don't seem to work. I've never had a tractor with glow plugs before so this is all new to me. I'm not much of a mechanic, more of a 'learn as I have to when things don't work.'
I did just replace the glow plug timer, as I read that is a common failure. Tried to turn on glow plugs - light on dash came on - good news.
In replacing the timer I noticed the wire to the glow plugs wasn't actually plugged in (aha!). Plugged wire back in.
Tried to turn glow plugs on - no dash light now.
Unplug wire - turn on glow plugs - dash light back on.
Does this mean the actual glow plugs are bad? Or some kind of short somewhere that happens when the glow plug wire is plugged in?
In all this the tractor still won't start. It is chilly, in the 30's. We have never been able to start it without ether, which I don't like doing so I really want to get this fixed. We haven't had it very long and have only run it maybe half a dozen times so I don't know it well enough to know what is normal and what is not for this tractor.
I did hear ether + glow plugs is very bad so if I need to run it I don't even try the glow plugs just in case. I was considering getting a block heater, I think Tractor Supply has them, has anyone had good luck with those?
I'm guessing next step is to test the actual glow plugs?
I was going to look for a video on how to use a multi meter to test things, I've used one a few times but am no expert there. You can use them to test for shorts, correct?
I also found a random black wire that I have no idea where it plugs into (see photo). I didn't know if it was related to this issue. I tried looking at the wiring diagram but I couldn't figure it out. The glow plug wire is unplugged in the photo.
I do know the previous owner replaced and moved the ignition switch to the left side so I don't know what wiring modifications (if any) were made.
Any help appreciated!
/ Glow Plug Issue #2
If the prior owner has done significant rewiring nobody here is likely to be able to pinpoint your problem. I will tell you sometimes glow plugs fail as a dead short instead of going open. You could certainly try replacing them or at least testing them as a first step. If removed from the tractor they may be tested individually. Frequently 10.5 volts is the correct voltage. You can get proper replacements directly from NGK without going through the tractor dealer.
/ Glow Plug Issue #3
You can also just get a temporary jumper wire and hook to the glowplug wire or to the flat bar on the glowplugs for about 20 seconds to start it rather than ether.
1-6 ohms is the resistance of a typical glowplug that is good. Remove the flat bar on the glowplugs and test each one.
/ Glow Plug Issue
Thank you - I haven't looked under the dash yet to see what the wiring looks like. That was going to be a spring task.
/ Glow Plug Issue
Good to know about the jumper wire for starting - will look into testing the plugs next.
My last tractor was an IH 454 and it actually had a button in the dash for a small canister of ether stored near the engine to start it, lol. No glow plugs, of course.
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
KBH Tender Trailer (A61306)
KBH Tender Trailer...
8' DISC HARROW (A60430)
8' DISC HARROW...
