Glow Plug Issue
/ Glow Plug Issue #1
hollywd75
Mid-Atlantic
NH TC30, IH 454, JD LX188
Hello,
I bought a 2004 TC30 a few months ago, the glow plugs don't seem to work. I've never had a tractor with glow plugs before so this is all new to me. I'm not much of a mechanic, more of a 'learn as I have to when things don't work.'
I did just replace the glow plug timer, as I read that is a common failure. Tried to turn on glow plugs - light on dash came on - good news.
In replacing the timer I noticed the wire to the glow plugs wasn't actually plugged in (aha!). Plugged wire back in.
Tried to turn glow plugs on - no dash light now.
Unplug wire - turn on glow plugs - dash light back on.
Does this mean the actual glow plugs are bad? Or some kind of short somewhere that happens when the glow plug wire is plugged in?
In all this the tractor still won't start. It is chilly, in the 30's. We have never been able to start it without ether, which I don't like doing so I really want to get this fixed. We haven't had it very long and have only run it maybe half a dozen times so I don't know it well enough to know what is normal and what is not for this tractor.
I did hear ether + glow plugs is very bad so if I need to run it I don't even try the glow plugs just in case. I was considering getting a block heater, I think Tractor Supply has them, has anyone had good luck with those?
I'm guessing next step is to test the actual glow plugs?
I was going to look for a video on how to use a multi meter to test things, I've used one a few times but am no expert there. You can use them to test for shorts, correct?
I also found a random black wire that I have no idea where it plugs into (see photo). I didn't know if it was related to this issue. I tried looking at the wiring diagram but I couldn't figure it out. The glow plug wire is unplugged in the photo.
I do know the previous owner replaced and moved the ignition switch to the left side so I don't know what wiring modifications (if any) were made.
Any help appreciated!
/ Glow Plug Issue #2
If the prior owner has done significant rewiring nobody here is likely to be able to pinpoint your problem. I will tell you sometimes glow plugs fail as a dead short instead of going open. You could certainly try replacing them or at least testing them as a first step. If removed from the tractor they may be tested individually. Frequently 10.5 volts is the correct voltage. You can get proper replacements directly from NGK without going through the tractor dealer.
/ Glow Plug Issue #3
You can also just get a temporary jumper wire and hook to the glowplug wire or to the flat bar on the glowplugs for about 20 seconds to start it rather than ether.
1-6 ohms is the resistance of a typical glowplug that is good. Remove the flat bar on the glowplugs and test each one.
/ Glow Plug Issue
Thank you - I haven't looked under the dash yet to see what the wiring looks like. That was going to be a spring task.
/ Glow Plug Issue
Good to know about the jumper wire for starting - will look into testing the plugs next.
My last tractor was an IH 454 and it actually had a button in the dash for a small canister of ether stored near the engine to start it, lol. No glow plugs, of course.
/ Glow Plug Issue
Pulled the glow plugs and tested, all three no readings. Ordered a new set, tested them and got readings, just installed them.
Same issue, won't start. Tested for voltage at the glow plug connector, got 12v.
If the glow plug connector is unplugged, the glow plug light on the dash comes on when activated. When I plug the glow plug connector in, then the dash light won't come on.
I've read other posts and people talk about a click coming from the timer. I am not hearing any click. I replaced the timer, no click from the new timer either.
It is pretty cold out, been around 25-30. Tractor is kept in a shed. Is it just too cold for the glow plugs? I was going to go buy a block heater next and try that.
/ Glow Plug Issue #7
Have you talked to NH mechanic? My Kioti has a controller and a relay for glow plugs. The controller adjusts time of run for plugs according to temps ( or so I was told).
/ Glow Plug Issue #8
Does the NH cycle glow plugs by partially turning key either right or left? For manually running plugs
/ Glow Plug Issue
I have not. I was hoping it was just a bad glow plug or timer as I hear that is a common fail, but no such luck. I have yet to hear the 'click' that people talk about.
According to a TC30 manual I read you are supposed to turn the ignition key backwards to engage the glow plugs. Mine seems to be different though. I have a switch that I pull out. I know the previous owner replaced the ignition switch (someone had broke a key off in it), so I'm wondering if he rewired the glow plugs to a separate switch. Now I'm wondering if he didn't connect something right - thinking I may need to look behind the dash now. He had told me the glow plugs worked though.. hmm.
/ Glow Plug Issue #10
Don't have a TC30 but a TC34. There is a click to mine when glow plugs are active and have cycled. 1st indent on key turns on glow plugs for 4-5 seconds then a click, turn key to last position to engage starter then release key to spring back to run position, Believe there is another relay tied to glow plugs besides timer, at least on my model
/ Glow Plug Issue #11
My John Deere had to turn key to left for glow plugs, then right to start. No timer
My Kioti is auto timer with manual backup if you hold key just shy of starting. But these glow plugs heat up to like 800°c in 4 seconds so don’t overdo it.
On yours, I bet they screwed it up rewiring switches.
/ Glow Plug Issue
Thank you, good to know from a similar machine. I looked at a TC30 wiring diagram and just see the timer and glow plugs. But mine could be different, I will check for another relay.
/ Glow Plug Issue
I’m thinking that as well, that something wasn't rewired right. Going to have to look behind the dash.
/ Glow Plug Issue
Bought a new TC30 ignition switch. It was easy to install because fortunately the old harness was still intact with the factory wiring, so pretty much plug and play. Getting the same issue. Turn key backwards to activate glow plugs and the dash light comes on, but still no click from the timer and tractor cranks but won’t start. Guess it’s time to figure out how to use the multi meter to find out what is going on here. Had really hoped the wiring to the old makeshift switch was the issue.
/ Glow Plug Issue #15
The TC30 is right between my earlier 1520 and my later T1520. I believe that TC30's have two different electrical systems. The earlier TC30's I believe are similar to my 1520 with the addition of additional safety swiches, including the seat switch. The later TC30's are similar to the newer T1520 where the glow plug lamp timer and the seat switch timer have been replaced with the safety controller. You indicate you have a glow plug timer, so I take that to indicate that you have an earlier TC30 without the safety controller.
I have wiring diagrams for my 1520, my T1520, and the later TC30's with a safety controller. I do not have a good schematic for the early TC30's so my statements here are based on my knowledge of the 1520, T1520, and later TC30.
First thing, is that there is no glow plug relay on a 1520, T1520, or later TC30, so I expect that the early TC30 does not have a glow plug relay either. The other, aka "deluxe", TC models, including the TC34 mentioned above, do have glow plug relays that are also controlled by the glow plug lamp timer. The glow plugs on your TC30 are turned on by only the ignition switch being turned to the heat position. I.E. the +12vdc at the ignition switch goes directly to the glow plugs via the wire & and couple connectors along the way.
Second thing, is that the glow plug lamp timer (that is what it says on it), on your TC30 controls only glow plug indicator light. It does not control the glow plugs. The glow plugs are energized as long as the key switch is held in the heat position. This is the same for 1520, T1520, later TC30's. So you will not hear any audible click when turning the key to heat. The other TC models, as the TC34 mentioned above, do have a relay that energizes the glow plugs and this relay is energized by the glow plug lamp timer. On those models you will hear the click of that relay and the glow plugs will only operate while the glow plug light is on.
If you turn the key and the glow plug light is on, and if the engine will crank, there is not much to check. The same +12vdc from the ignition switch that is energizing the glow plug lamp timer should be going to the glow plugs.
I also suspect that another way to tell an early TC30 from a later TC30 is by the location of the heat position on the ignition switch. If you turn to the left for heat, that is the same as a 1520 and might be an early TC30. If you turn to the right for heat (between off and on), that is the same as a T1520 and might indicate a later TC30 with a safety controller. If your TC30 has the same ignition switch as a 1520, terminals 17 & 19 are tied together and go to both the timer and the glow plugs.
/ Glow Plug Issue #17
After taking another look at the photo, in reference to the loose wire, the only thing that I can guess is that it is the wire that goes to the fuel shutoff solenoid on the injection pump. Shouldn't be any other wire in that area of that length and with a 1/4" spade connector. I believe the wire being disconnected from the fuel solenoid would also cause a crank but no start condition. If that is what it is, there should be plastic housing over the connector as it will be +12vdc when the ignition is on, i.e. check the fuse
The added fuse and the scotchlok connectors are evidence of electrical modifications so that could be an issue too. Might check to see if there has been some wiring change made to the fuel solenoid, perhaps to defeat the seat shut off switch?? I do not consider scotchlok connectors to be very dependable over time. I prefer butt connectors with shrink tubing for sealed connection.
The electrical schematic provided above by skramer360 does confirm that there is no separate glow plug relay. The ignition switch wire runs to the glow plug connector that is disconnected in the photo. The glow plug lamp timer only controls a glow plug light on the dash.
/ Glow Plug Issue #18
Well the OP had out the wire diagram so that's a Google start. You can test most things on this system with a test light. I would start by actually checking for power at the glow plugs. Then work backwards to the timer or relay. If you get stumped find what wire powers them from the Key switch.
You could also jump 12v to the actual glow plugs and see if the machine starts. I would only supply power for about 5sec though.
/ Glow Plug Issue
Thank you all for the detailed replies. I have been working on the tractor and figured some things out. In the previous owner's non-factory ignition switch, he had an added white wire running from that switch to the injectors. I replaced that switch with factory one, removed the added white wire, and connected that black loose factory wire - that mystery solved.
Thank you for clarifying about the 'click.' Yes, mine seems to be the older model. I verified the glow plugs work by connecting them to a battery. Reinstalled. Even removed one after using the heat setting (turn key backwards) and the glow plug was warm. Plus I just installed these plugs, and I could tell by the ends no longer looking 'brand new' that they were working.
I wondered about that added fuse and that bit of wiring there. I didn't see that fuse on the wiring diagram so wondered what it was for. I think you are right, that it bypasses safety switches.
Good news - verified working glow plugs.
Bad news - tractor still won't start without ether. Cranks but won't turn over. We are in the deep freeze like everyone else. It's in a shed, so I got out the propane heater and heated the shed quite warm - probably like 50 degrees. Still won't start with glow plugs. Started out with a fully charged battery (keeping the trickle charger on in this weather).
It will start if I aim the heater at the engine for 30 min or so, and use a couple shots of ether (disconnected glow plug wire first).
So I no longer have a glow plug issue - now it's a starting issue - maybe time for a new thread?? So frustrating. There seems to be lots of 'TC30 won't start' threads.
Oh and both battery cables have been replaced with new ones.
I got the service manual too. Thank you everyone for the help - this has been a learning curve! Frustrating, I just want to be able to start my darn tractor without ether.
/ Glow Plug Issue #20
Kind of sounds like you have gelled fuel.
