Glow plug issue
/ Glow plug issue #1
Mikemeller
Mahindra emax 22
Glow plug light on dash will not come on location of fuse for glow plug
/ Glow plug issue #2
Have you checked the lid on the fuse box? Usually there is a list there that says what fuse does what and its current rating.
/ Glow plug issue #3
Have you checked that the plugs are getting power when operated, could just be the bulb.
/ Glow plug issue #4
If the fused are good then you probably also have a relay in the circuit, you might check it to see if it gets energized.
Do you hear any ticking sound?
/ Glow plug issue #5
Probably no fuse for glow plugs, only for the relay and/or timer. They usually use fusible links for the power thru the relay to the plugs. You need to get information on your particular model to see how it operates instead of everyone guessing what could be wrong.
/ Glow plug issue #6
Didn't ask before, does the tractor start, you don't need them to start. On my 2815 the circuit covers the glow controller, fuel pump, alternator and couple other items is protected by the same 10 amp fuse.
Roll of Plastic Hose (A64119)
Roll of Plastic...
2017 Ford F-150 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
2012 Ford F-350 Western Mule 1,500 LB Crane Service Truck (A61573)
2012 Ford F-350...
UNUSED ATSPOWER ATS-SP50 50 TON HYD SHOP PRESS (A64281)
UNUSED ATSPOWER...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
