The glow plugs can also be manually activated on these early JD 4100's independent of the timer. You could also try this for a quick check...engage the dash PTO switch and then hold key in start position for several seconds. Disengage PTO switch then start again, If you easily start chances are the glow plugs are still good and the timer failed. If there's no change then follow the instruction outlined by George 2615 in the prior post to check the condition of the glow plugs.
A timer failure can cause other problems too most noticeably a lack of charging at the battery. That is what happened when my timer failed.
What was happening I eventually found out was that current was being applied continually to the glow plugs circuit thru the failed timer (contacts didn't open after the timed interval) and the alternator could not keep up with the continuous current flow and eventually the battery would become discharged enough that the tractor would shutdown
So I just unplugged the wire harness going to the timer module and all was good again (charging correctly) I haven't replaced the timer since and just use the manual override now.
