Glow plug indicator
   / Glow plug indicator #1
terry skinner
Roy,WA
mitsubishi/180
The little resistor coil in the dash of my Mitsubishi 180D has burned out. Looks like rust is the cause. I cannot find a local tractor dealer that has anything close. Are there any suggestions as to where I can locate this part?? Or does anyone have an idea what the resistance is?? So that I can replace it with something else. I am afraid to hook it up direct . Don't want to overload the glow plugs.
Thanks from out here in the Pacific NW...............Terry
Part #
MM409515
NGK 29 A
DH-139V-29
   / Glow plug indicator #3
There is a guy in West Linn oregon who parts out tractors you can find him on the portland craigslist.
I also like the tractor store in eugene oregon.
Good luck
Thanks. I will give them a call on Monday. In the mean time I was able to pry off a little bit of the resistor coil and attach it to a new bolt. She started up just like that (snapping finger) and ran just fine. Still want to replace with a new one. Kinda worried about over loading the glow plugs. Those little puppies an't cheap!! Thanks again...........Terry
Good luck
I found the guy in West Linn and will call him Monday too. Thanks guys. Hope I can do a payback.............Terry
   / Glow plug indicator #6
A piece of "Nichrome" wire, but of the correct gauge. Nichrome is what you would find in a toaster or small oven, but you need the proper gauge.
Funny thing happen today, I had a piece of stainless wire short against my stinger and ground welding today and it lit up nice and orange with about 80 amps going through it. I wonder if something like that might work?
   / Glow plug indicator #7
Nichrome wire is indeed the proper stuff to use.
The reason being that it will not rust/corrode and keep its resistance value.
Gauge is not that important as is the proper total resistance.
If you can get a reading (ohms) of the old coil, replacing with a home made would be easy enough to do. A short length of nichrome giving same value will do the trick.
A caution is that you can not solder ends (solder will melt) so only mechanical connections will do.
   / Glow plug indicator #8
I like the nichrome wire advice. I did once find/buy an OEM Mitsubishi G.P. indicator off Ebay but they are rare. My next go around, I bought one of the Kubota compact tractor indicators ( they are listed as being for all B, L models and even some M's up to about 60HP) and swap the resistor wire coil to the Mit's indicator housing. The Kubota's "lamps" are usually available for $15+/- including SH.
   / Glow plug indicator #9
Odd mine has yet to fail after 30+ years of abuse. I man use.
   / Glow plug indicator #10
Nothing odd....that's just good Ol' Mitsubishi service!! I have only replaced mine because my key will stick in "heat" position and my sons have left it on for ????......they can/WILL eventually burn out if left on repeatedly for super long periods of time.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
