glow plug indicator on a satoh beaver
   / glow plug indicator on a satoh beaver #1
jerryjg
Willow Spring NC
Satoh Beaver S-370
the glow plug indicator smokes a little when I put the switch to heat then the coil gets red hot for 10 t0 12 seconds then fades to a dim red almost can not see it glow. I have rewired with new wires and switch. how long does the glow indicator typically stay red. the tractor had a push button installed with appliance cord when I got the tractor, so I have rewired the tractor.
   / glow plug indicator on a satoh beaver #2
Mine does not stay red very long at all. The moment I turn the switch in the direction of start, it fades immediately.
   / glow plug indicator on a satoh beaver #3
My glow plug indicator will glow red after about 15 seconds or so and stay glowing red until I release the key. If you have a heavy duty amp meter you could put it in series - that would tell you if something has opened in the circuit when your indicator stops glowing. If not that, then if you can test for continuity across the indicator before it cools, it may be that its opening up as it heats. From your description, it would sound like you have a heat sensitive 'open circuit'. Good luck finding the faulty location!
What is the ambient temperature you're trying to start the tractor in? An alternative I have used when I was having glow plug problems a couple winters back was to carefully blow warm air into the air intake hose (past the air filter closer to the engine) with a heat gun on low. Of course be very, very careful to not get the intake hose too hot. The tractor would start without the glow plugs doing this. The temperature was in the 20s when I used this method.
   / glow plug indicator on a satoh beaver #4
Hi sir,
Nice machine you have there. I also have a S370D Satoh-Beaver, and looking to replace the glow plugs.
Could you tell me if a ngk 6825 will fit. Or if you have another parts number i should get.
Thank you.
seamonster
I got my glow plugs from Dixon ill. shefortractor. not sure about ngk. still can not get mine to start I installed a 30 amp relay with feed from battery use switch to pull relay for glow plugs the switch is not rated to pull glow plugs it is made for relay less amps. I think I will take the injectors and have them checked next. still a work in progress. also stevens tractor in la. sell parts for the satoh.
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
