Glow plug indicator not heating up - why?
/ Glow plug indicator not heating up - why? #1
orange1
I have a Kubota B7200. Prior to today, the glow plug indicator would heat up and the tractor would start right up. Now, I turn the key to the left, wait up to a minute, and no heat, the tractor did not want to start. It finally started. I shut it down, let it sit and tried it again - still would not heat up. What could be causing this?
/ Glow plug indicator not heating up - why? #2
A blown fuse, broken wire, or a bad relay would be my first guess. But with a schematic and a VOM you could trace out the problem.
/ Glow plug indicator not heating up - why? #3
It could be as simple as a disconnected wire. I had this happen to my BX22 and just fixed it. Pic attached. The wire was supposed to be attached to the threaded post you see without a nut on it. Engine vibration must have loosened it and presto. No more glow plugs.
/ Glow plug indicator not heating up - why? #4
Glow plugs are consumable items, could be one or more have worn out. You could diagnose this with an amp meter to see if any current is being applied to the glow plug, if it is dysfunctional it will not have any current draw.
/ Glow plug indicator not heating up - why? #5
I'm not real familiar with that model. Does it have the light or the coil that starts to glow cherry-red as it heats? If it is the first style if it isn't a wire it may be the timer or relay. If it is the other style and the indicator doesn't do anything, it could be the indicator itself. If the indicator is bad on the tractor the glow plugs don't get any juice. From the wording of your post I would say you have a bad indicator. It sounds like it is the second type also.
KO
Thanks for the advice Kiohio. It has the second type you described with the coil that turns red. The weather here has been all rain the past couple of days. I will check it when the rain stops and I can take the tarp off the tractor - I am in the process of putting up a 24' X 40' storage shed for the tractor and equipment.
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
2006 Toyota Tacoma (A66408)
2006 Toyota Tacoma...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
Homemade Utility Trailer (A62613)
Homemade Utility...
Behlen Grain Bin Aeration Fan (A65640)
Behlen Grain Bin...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
