Glow Plug and fuse system
/ Glow Plug and fuse system #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
Homier 2425 need to know which is the fuse for the glow plugs. And also a layout for all the fuses. Thanks
/ Glow Plug and fuse system #2
Depends upon the engine and the age. Not sure about 2 cylinders. Earlier 3 cylinders didn't have a dedicated glow plug fuse. The only protection was the 30A system fuse.
Seems I asked this question before. You didn't get manuals with that tractor?
//greg//
3 cyl and have 07. I probably have asked. No I did not check. I make a list of all the things around my place that need to be done. Then in the Spring winter problems don't get done. Then the snow comes and I start all over. So I need to look at my 30a first. If the battery is older the glow plugs would still register a pull on the battery?
I changed out all my 30a need to do all. Got a charge change when putting a pull for the glow plugs. Seem to have glow plugs back working.
I have everything working now thanks for the information. :)
2007 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2007 JLG 600S...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN#7FWBE1620T1037828 (A61166)
2026 Steel Pines...
DEUTZ MARATHON...
832660 (A61165)
832660 (A61165)
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
