Glow light stayed on
/ Glow light stayed on #1
lakngulf
Lake Martin Alabama
Kioti CK30
We got 2.5 inches rain last night and CK30 was outside. Went to bush hog this morning, key on, clutch in, glow plug indicator on, goes off, crank tractor, let out on clutch and light back on. Clutch in OFF. Clutch out ON.
I begin mowing and light finally off after 15 minutes
Do i have anything to worry about?
/ Glow light stayed on #2
Very long glow times will deplete the battery and wear out glow plugs prematurely. Fifteen minutes is too long but it's not a disaster.
But the glow light doesn't necessarily mean the glow plugs are actually powered. I recommend you wait to see if the problem fixes itself; maybe this is caused by trapped water and will resolve. If the "problem" persists, use a voltmeter to determine if the glow plugs are truly powered or if it's an indicator problem.
Worked today as it should with no problems. Than ks
/ Glow light stayed on #4
Happened to my CK30 when it was new. Relay stuck on and flattened the battery. I was concerned it may have damaged the Glowplugs but 9 years later they still work. Relay was replaced under warranty.
/ Glow light stayed on #5
My glow plugs stayed on when the timer relay went bad.
Ford F800 (A63689)
Ford F800 (A63689)
2016 Ram 2500 6.4L HEMI (A62679)
2016 Ram 2500 6.4L...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
