Glossary
   / Glossary #1
RedRocker
Veteran Member
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
I'm new at this tractor stuff, is there a glossary somewhere?
I've figured out the FEL and ROPs stuff, but the MMM and TnT are still a mystery. Thanks for your help. Mike
   / Glossary #2
How about this old thread, started by Muhammad back in 2001. /forums/images/graemlins/grin.gif
   / Glossary #3
First off, that is a good thread Bill posted. I didn't go through the whole thing, but I did check out the original post by Muhammad. It should help alot. /forums/images/graemlins/smile.gif Now, on to MMM and TnT.
MMM - mid-mount mower
TnT - Top N' Tilt
   / Glossary
Thanks guys, I just knew there had to be one, we have the same deal on the Cummins turbo diesel site. What exactly does the top n tilt do?
   / Glossary #6
</font><font color="blue" class="small">( What exactly does the top n tilt do? )</font>
The "top" part means replacing the manual screw type top link with a hydraulic cylinder that is then used not only to make it easier to hook up implements, but to tilt them forward and backwards with a hydraulic lever. Lets you do it "on the fly" and is especially helpful when using a box blade. The "tilt" part means replacing one of the side links with a hydraulic cylinder that lets you tilt implements side to side.
   / Glossary
Thanks again, now I know everything /forums/images/graemlins/grin.gif. NOT
I'm getting there, I appreciate the info.
   / Glossary #10
I thought FOPS = Falling Object Protective Structure, was
FOPS = Fold Over Protective Structure?
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
FULL ACCESS TOOL BOX (A50854)
FULL ACCESS TOOL...
