glide shift/power shift
/ glide shift/power shift #11
No problem here, actually I should have said the Gand L GST has 12 gears. I don't know about other models, so I should have just stated that was on the 30's.
/ glide shift/power shift #12
On the 790 you will have a tricky time shifting while rolling. You may get the hang of double clutching and be able to do it without grinding, but either way it is tricky. On my MF with a 12/3 tranny, i can shift from 1-2 (and back) in all three ranges while rolling; also R-2 (and back) without any grind. But for some reason - the way the tranny is designed, I have to double clutch to shift from 2-3 or 3-4.
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
