Glass for gauges
   / Glass for gauges #1
Oakley
2002 Kubota BX2200
I'm going to look at a Ford 1900 tomorrow and the owner said the gauges work, but are missing the glass. Can it be replaced without having to replace the gauges?
   / Glass for gauges #2
Probably not easily. You will need to replace the whole gauge unless you can figure out how to take off the benzle and cut a round piece of glass.
Aaron Z
   / Glass for gauges #3
There are shops that works on instruments for cars and tractors, speedometer shops can probably fix it.
   / Glass for gauges #4
Taking a look at this thread ( New gauges for the 1900 ) it appears as if they are just standard gauges and you will probably be time and money ahead just replacing them. A shop might be able to replace the lens, but the price will probably be double what replacement gauges would be.
Aaron Z
   / Glass for gauges
Than you, both!
   / Glass for gauges #6
There is a plastic film that can be removed I believe on both inside and outside faces, but I could not clean the film off. The price for new lenses are so cheap why go through the effort of trying to clean them. I purchased a new fuel gauge lens from Pelican and the diameter was smaller than the original. I almost sent it back but I made it work. It was just barely big enough to fit behind the lens frame, any smaller and the edge would be showing. I'm not sure why the diameter was cut so much smaller than the original. Like someone else mentioned...You can get this glass cut yourself locally. Take the lens out, take it to a glass shop and they will make a replacement. The pelican lens is just a cut piece of glass, nothing special that can't be replicated, in fact, it is thinner than the original plastic lens.
______________________
company
   / Glass for gauges #7
IF you could take the gauge apart and the original gauge is of value, you might be able to buy a cheap chinesium gauge and rob the glass.
   / Glass for gauges #8
Long, long time ago flashlights had glass lenses. Popular Mechanics ran a shop tip. I assume it was single strength glass. They used magic marker, drew circle on glass. Then using rubber gloves, scissors and bucket of water, they cut it out under water. Water reduced shock waves or something?? Never tried it myself, guess it made an impression on me.
   / Glass for gauges #9
I was thinking of flashlight glass lenses too. Hardware stores used to have a box of lenses on display of various sizes.
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
15200 (A56857)
15200 (A56857)
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
2017 Ford F-150 Single Cab Pickup Truck (A55973)
2017 Ford F-150...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
