GL5030 V. DK55
Status
Not open for further replies.
/ GL5030 V. DK55 #21
Sure, something good can come out of this topic. People can learn to make honest comparisions. Why would someone compare a Utility Tractor to a Compact Tractor other than to show that it is not a fair comparison???
Neil is correct, the "M" series Kubotas are not only less expensive than the "L" series Kubotas, and they are also larger/heavier machines as well. The "M" series machines are Utility Tractors, they offer more steel and iron in a more basic design. And as the "M" series machines cost less, it strikes me that a fair comparision between a Kioti Utility tractor and a Kubota Utility tractor may actually have the Kubota at the lower price.
If you want to make a big cheap tractor just load it up with cast iron housings, heck the Rural King Tractor Kings are great for that, they are bigger and beefier than the Kioti DK55 or the Kubota M series tractors and they are cheaper too. I used my brother in laws Tractor King and I don't think Kioti can even begin to touch it on price.
/ GL5030 V. DK55 #22
</font><font color="blue" class="small">( Uh-oh. Nothing good can come out of this topic. /forums/images/graemlins/confused.gif )</font>
Well sure it can! /forums/images/graemlins/smile.gif We can talk about the new look M-series looking remarkably like the Kioti DK's. /forums/images/graemlins/shocked.gif
It can be good. /forums/images/graemlins/grin.gif
RedDog
/ GL5030 V. DK55 #23
Too late. It's already started................. /forums/images/graemlins/smirk.gif And by the way, I made no comments on manufacturers, models, etc, only on what I thought would happen on a topic such as this.
/ GL5030 V. DK55 #24
Hodak,
I do believe the new M's look remarkably like the new DK's, just as I believe the older Kioti's look remarkably like Kubota's.
I fail to see how that is too late. /forums/images/graemlins/confused.gif
RedDog
/ GL5030 V. DK55
All I can say is this...
Look at the M series, look at the GL series, look at the DK series...you get all the "high end features" of the GL with the "utility" of the M with a DK. Here are list prices on these machines.
GL5030 = $25,060.00
MX5000 = $21,300.00
DK55 = $25,067.00
So, the M series is a little cheaper...but it doesn't have a lift valve at the rear, doesn't have 2 aux. valves standard, doesn't have a self leveling front end loader available, doesn't have a 12x12 transmission and doesn't spec out ANY better than the DK55...in fact in all the important areas is specs out worse. Does that MX5000 have tilt steering or splash guards? Oh, and the MX5000 gives up nearly 1000lbs.
I don't want to start a fight here guys, but just look at the specs...I know which tractor I would want, the one that combines the most standard features with the best specs possible. Not to mention the few things Kioti offers that Kubota doesn't. I am not here to rag Kubota, they wouldn't have made it to where they are today by making junk, thats not my intent. My intent was to put these pictures up for everyone to see and make their own conclusiong to them... and do it peacefully! /forums/images/graemlins/smile.gif
/ GL5030 V. DK55 #26
Hodak . . . I agree with what you wrote, I was just pointing out that Neil made some very good points. I also was simply pointing out that if you want to get really nit-picky about it, then the Chinese tractors offer far greater value than either the Japanese or Korean brands, they offer higher weight which is important in some circumstances, and they offer beefier castings.
Gambel77 . . . I'd suspect the Kubota's $4000 price advantage would allow one to purchase the rear remotes and several other features if the tractor buyer wanted or needed them. Oh and he'd still be able to pocket a few $$$$ after adding them.
As for weight, the last time I checked with the farmer who leases my fields, he was very concerned about reduced crop yield due to compression of the soil. In fact there is a big movement in agriculture to reduce weight and soil compression by switching over to lighter equipment and/or rubber track machines. Last year I read a long paper by Goodyear tire on efforts to reduce compression as well by utilizing proper tire design, altering travel patterns in the fields, etc. Weight is a big deal and becoming a bigger deal as they find that excess weight reduces crop yield. But if you really want the weight, I'd still suggest the Chinese tractors.
/ GL5030 V. DK55 #27
</font><font color="blue" class="small">( Hodak,
RedDog )</font>
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
I see no comparison in looks.
murph
/ GL5030 V. DK55 #28
I fail to see how having more weight on the standard tractor is a bonus. Its easy and cheap to add weight, but if its already there you cant remove it in places where a light tractor is best.
/ GL5030 V. DK55 #29
Just for another perspective, here are some Rural King photos. This tractor is sitting on a lot here in Indiana right now. 82 hp Perkins powered Tractor King. It has heat and A/C. It is "Beefy", weighing in at 9500 pounds without a loader.
This tractor on sale for $16,900 because it has a little sheet metal damage. Add about $4500 for a Koyker loader and you would have a 12,000 pound tractor with CAB with heat, A/C, dual rear remotes, bigger tires, axles, etc all for around $21,400 plus tax.
/ GL5030 V. DK55 #30
Here is a shot of the rear end.
/ GL5030 V. DK55 #31
Another shot of the rear end, wider view.
/ GL5030 V. DK55 #32
Here is an shot from under the tractor showing the rear axle from the front toward the back.
/ GL5030 V. DK55 #33
Here is the front end, showing the suitcase weights (which are included in the price of this tractor). It is hard to compete on the weight, value, size with Tractor King.
Fact of the matter is that anyone can built a big bulky tractor and offer it at a reasonable price. Tractor King's are proof that you can get a lot of weight, a lot of cast iron, and a decent cab for a great price.
Now is this a 'fair' comparision to the DK55? The price is lower. It has features similar to those found on the DK55. Plus a nice cab with heater and AC. Perkins engine too. Bigger, heavier. Dual rear remotes. Big strong iron axles. No question this is a utility tractor not a CUT.
/ GL5030 V. DK55
Just to clear things up, are we now comparing a 82hp tractor to a 55hp tractor? I was at least trying to stay in the same hp range. I understand Bob that you are trying to validate your point about money and "beef" but lets at least compare fruit to fruit!
And I don't know about the rest of you guys but the front end on that Farm King looks awful thin...could just be the angle...
/ GL5030 V. DK55 #35
Just from reading the thread, it looked to me that you were emphasizing weight and price while also talking about power. From what he posted, it sure looks like considerably more tractor for the money which is the point you seemed to be making. I believe that you will have the wrath of the entire Chinese tractor section if you try to say that their tractor is "thin" when it weighs considerably more than your offering and is a minimum of $5000 less money for a lot more hp and tractor. Besides, unless I read it incorrectly, it is powered by Perkins. Isn't that what the higher end Kioti tractors use?
/ GL5030 V. DK55 #36
Actually it seems pretty fair to me. I suppose it depends on exactly what you want to compare. I was comparing size & weight as a component of the value you get for the price. Isn't that what you did?
The Tractor King, with loader, cab, dual remotes, Air Conditioning, Heater, and Front End Loader is in the same price range as the DK55 so I figured it was an Apples-to-Apples comparions. Further it is the same class of tractor, being that it is a Utility Tractor and certainly NOT a Compact Utility Tractor. So being the same type, and in the same price range, it strikes me that it is a pretty good Apples-to-Apples comparison.
For a Utility Tractor in the Low-Mid $20K price range, it is bigger badder and meaner than anything else out there that I have seen. It certainly has plenty of features so it would compare well with the features of the DK55 Utility Tractor your put up against the Compact Utility Tractor.
Actually I think I did a better job of staying with the same type of fruit than you did. And I showed one heck of a value too.
JMHO
/ GL5030 V. DK55 #37
</font><font color="blue" class="small">( Ok guys before you look at these I am not posting these to start any arguments or whatnot about any particular brand of tractor. I am just posting these pics so take them as you will. )</font>
Well what you say you didn't want to do, you did. Now the question is deep down inside did you really want to start a war?? No you didn't make any real bad comments about the other tractor but the way it was set up, others did.
As a dealer of any product you need to know something, Sell your tractor for what it is and leave the others out of it. I own a large business, I and my partner are Ford fans. And everytime a Chevy guy comes into our office and bad mouths another product we pretty much tell him to leave. That is why I didn't buy a Kubota in the first place. That is about how I felt about your post especially now when there is discussion about you comparing apples to oranges. For all I know they may be comparable, don't know but the fact people are contesting makes me wonder. If doing a comparison why only a Kubota, why not other makes? And it should probably be out in the General forum, but you put it in the Kioti forum as a place for all to knock the other brand. Did you just loose a sale from the Kubota dealer? Again you being a dealer makes it tough for you to do the comparison as you are a Kioti dealer and your naturally going to be bias.
Just constructive criticism from a consumer to a sales person.
murph
/ GL5030 V. DK55
I am selling my product, and the GL5030 is what I have to sell it against, why you ask, because that is what the other orange guys in my area sell againts the DK55. I don't have every other make of tractor on my lot or at my disposal to make photo comparisons with. I kept two factors in mind when comparing these tractors, PTO HP and $$. Comparing a 82hp tractor to a 55hp tractor in my mind is stretching a little too far. Murph, I didn't post this in the Kioti forum to bash anyone, in fact thats what I was hoping wouldn't happen. I have not lost any sales either...I am installing a hydraulic chipper shredder onto the L5030 and thats the only reason I have it at my disposal.
Bottom line gentlemen is when customers, who know nothing about tractors, start to compare they look at two things first, hp and $$. Once they have that narrowed down they hopefully start to compare feature for feature. A person looking at a DK55 is not going to look at a Farm King 82hp tractor, but is MUCH more likely to look at a GL5030 or even an M5000...
Thats why this comparison made some sense to me. Not because we can sit here and disect DK55vGL5030 to death but because people do compare these machines, they don't however compare an 82hp tractor to a 55hp tractor. Does that make sense...can you find some logic in that?
/ GL5030 V. DK55 #40
DK55 = $25,067.00
I don't want to start a fight here guys, but just look at the specs...I know which tractor I would want, the one that combines the most standard features with the best specs possible. )</font>
Ok call me silly, but you are trying to define your fight in such a way as to show you have the best value but then you change the rules when I show another tractor that is also a great value?
Doesn't seem fair to me that you would do that.
You showed a UTILITY tractor and compared it to a COMPACT tractor.
You brought up PRICE
You brought up FEATURES
You brought up WEIGHT
You equated all that to VALUE
I showed a UTILITY tractor that outspecs your UTILITY tractor.
I brought up a lower price.
I brought up lots of features (including a cab and front end loader)
I brought up MORE weight.
Why is it unfair to compare the Tractor King? (made by Foton)
Are you saying that it is not as good a value as the tractor on your lot? It seems like a better value. It costs less, weighs more, has more power, and more features.
On thing I see is that some dealers try to compare tractors and as long as "their" tractor looks better then they are happy, but when someone shows them a better tractor for less money then those same dealers claim that the comparision is unfair.
Well I think that is boloney and you trying to change the rules is unfair! I'm playing by your rules. There were a few posts in this thread that said more weight is more important; I posted a tractor with MORE weight. There were posts that talked about size; I posted a BIGGER tractor. You talked about money; I beat your PRICE.
These are your words: </font><font color="blue" class="small">( I know which tractor I would want, the one that combines the most standard features with the best specs possible. )</font>
Based on your criteria, you should be driving a Tractor King.
/forums/images/graemlins/blush.gif
Status
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
213089 (A64276)
213089 (A64276)
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
25057SFL (A64557)
25057SFL (A64557)
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
1457 (A65054)
1457 (A65054)
