GL4 or GL5 front axle lube
   / GL4 or GL5 front axle lube #21
There were some manual transmissions that used ATF and using a heavier oil would take them out. The oil passages were to small to allow the heavier oil to lube it properly.
   / GL4 or GL5 front axle lube #22
Just a point to note:
Gear oils in the 80 and 90 weight category are not necessarily "thicker" than 30- 40 weight motor oils. The two lubricants use different viscosity scales.
Some people feel " thicker is better. but no... not so.
Sure seems thicker to me.
a 90 wt gear oil is the same viscosity as an SAE 50 oil, they are measured on different scales. It's the additive packages that differ.
   / GL4 or GL5 front axle lube #23
ISUZU Trooper II manual trans used ATF.
A very nice gearbox in my experience.
   / GL4 or GL5 front axle lube #24
I bought a 2007 65 HP tractor specifying UTF for the front axle. Bought the same brand in a 25 hp unit in 2016 and it said 80w-90 in the users manual and on the fill plug.
I had bearing failures on the 65 due to some mistakes I made in hopping clods with a bucket full of gravel. After I fixed the problems I decided to install 140 weight since I live in Texas, otherwise would have been 90w. Haven't had a problem since and it may be the oil or may be that I am more careful....but with the later year-model, much smaller tractor having gear oil specified spoke volumes to me.
   / GL4 or GL5 front axle lube #26
If you are answering me, yes....multi-viscosity heaviest weight commonly available.....I forgot the number for the cold viscosity.....maybe 80w. I think I bought some synthetic that was 75W-120 in a quart bottle once.
   / GL4 or GL5 front axle lube #27
I had a Toyota 4Runner with a 5spd manual transmission at one point.
Did a drain/refill and used GL5 thinking newer=better. Immediately became harder/rougher to shift through the gears. Researched and read it must use GL4 or you get this very problem. Did another drain/refill with the GL4 and it was back to smooth shifting.
Not sure what the mechanism is as to why the GL5 creates a problem in these; but the synchros are made of brass/bronze type alloy and it would follow that given the symptoms were with smooth shifting it has something to do with the synchros
Older Toyota manual vehicles call for 75/90 gear oil in trans & transfer case not 80/90.
(80/90 in differentials). both GL5. using 80/90 in your manual transmission could have accelerated shifter linkage & syncro wear, esp during winter in your location etc.
given OP's location, i'd go with 75/90 gl5 conventional gear oil for ft axle in tractor
best regards
   / GL4 or GL5 front axle lube #28
A bit off topic... One of my jeeps uses GL6 in it's rear axle (high pinion 9"). Try finding that stuff on a shelf at an auto parts store.
Or the GL1 my Willys calls for. šŸ˜†
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
20 LOWBOY BUMPER PULL TRAILER (A58216)
20 LOWBOY BUMPER...
2011 GMC Yukon XL Denali SUV (A56859)
2011 GMC Yukon XL...
Kubota RTV-X900 4x4 Diesel Utility Cart (A56857)
Kubota RTV-X900...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
