Give Me Forty Acres . . . And I'll Turn This Thing Around!
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
GIVE ME 4 ACRES by THE WILLIS BROTHERS - YouTube
First tests of new to me Bannerman Top Dresser.
Mostly a success.
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #2
IT - what do you lay down with that top dresser. Wood chips??
That is the idea. But also limestone screenings for the driveway.
Never realized that getting a Chipper would be the hardest work I have ever done! So I am trying to make the job more streamlined.
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #4
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #5
Lordy - I should guess. A PTO driven chipper with 12" capacity. You must have a team of gorillas helping with the chipping chores. So with the top dresser you can lay down a layer of limestone screenings on your driveway.
A chipper (I found) is pretty much worthless, unless you can get the downed or dead trees, mostly in the middle of the forest and in difficult terrain, INTO the chipper, and then somehow get the chips, where you want them. You do some firewood and cut a couple of trees down, but with the chipper you are hauling a dozen trees to chip, before that top dresser is full!
The chipper actually has a 15" throat which is a nice feature, even if the tractor is somewhat underpowered for the chipper. My next project is to build an autofeed system, to stop and start the feed when the RPMs drop on large material.
I really don't know any other way one can do this. I mean, once the chips are in the Top Dresser, this took about five minutes or less! Kind of hard in the picture to tell between fallen leaves and chips.
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #8
Looks like a nice, even layer.
   / Give Me Forty Acres . . . And I'll Turn This Thing Around! #9
Looks just fine to me. I just finished chipping all the small pines along my mile long driveway. Where the chips are - very nice, soft, little to no dust. I have no trouble getting my tractor & PTO driven Wallenstein anywhere on my property. One advantage to having 100% Ponderosa pine forrest.
And then, what do you do with the chips as they are made?
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
