GFI tripping
   / GFI tripping #11
Paddy said:
Ok. I've got an issue with a GFI breaker triping that feeds an outdoor water garden. I have tried several things that I feel has isolated every link in the system and it still trips...some times. It may go a week just fine or just a few hours.
We have a few GFI breakers for indoor bath rooms. Off one of these GFI breaker circuits, the line feeds the pond pump.
1 I replaced the pump that had worked fine for over a year, still triped
2 Pluged an extension cord into a garage GFI recptical, still triped
3 Changed wires in main breaker panel from GFI #1 to GFI #2, still triped
So the entire original run, breaker/wire/out door recptical and pump have been replaced with new or as with the breaker just switched. The wire being eliminated via an extension cord may not be a good test. The pump is a utility pump used to pump out a wet basement and maybe the small GFI recpt in the garage could not handel the load? So maybe I need to run a new pc of romex to a new recpt by the pond. This is no easy task because the wires are in a wall!
Any ideas?
Patrick T.
I only use these things when I have to. I wired the bathroom exhaust fan
through a GFI.sometimes it would trip sometimes it was fine. I found out that it was sensing feed back from the electrical motor on the exhaust fan & would trip at times I re- wired the fan & bpassed the GFI. Yours mabe sensing electrical feed back from your pump motor
   / GFI tripping
Bird,
I will try a clean job. As far as other coments about over heating. It has trip with just a few mins of time. So not likely
Patrick T.
   / GFI tripping #13
i've had the same problem: my pump house has 2 separate circuits: one 240V for a pump: and a totally separate 120V line for another pump and lights: i use one of the in line GFCI boxes to put power to tools when i'm working on something in or near the pump house: and it will kick when the all sorts of things happen: like the 120V pump kickin on, or sometimes when i turn the light on: and those aren't even hooked to the GFCI box.
heehaw
30006 (A55758)
30006 (A55758)
2011 Ford E-350 Passenger Van (A55788)
2011 Ford E-350...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2023 FORD F150 PRO LIGHTNING CREW CAB TRUCK (A51406)
2023 FORD F150 PRO...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
