Getting started ?
/ Getting started ? #1
John Stroud
214 John Deere
Can anyone help with the wiring on a JD 214 ? The solenoid , I thought was bad so I replaced it. This didn't help. I switched the wires back and forth but to no avail. The solenoid was not identical to the old one, but has 2 large posts for batt. & starter connection , & 1 post for the plug on wire. Can anyone help ?:
/ Getting started ? #2
im assuming that you have a fully charged battery. if so check for power at the small wire, you should have power with the ignition switch in the start position.if there is no power suspect faulty ignition switch or check to make sure the pto switch is off. if power is present check for power at the starter. you should have power with ignition switch in start position. if there is power, suspect faulty starter. if no power than you probly got a dud solinoid.
HARDEE DB4060 DITCH BANK CUTTER (A63745)
HARDEE DB4060...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
WARN XD9000i 12V ELECTRIC WINCH (A63290)
WARN XD9000i 12V...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
