Tires Getting ready to install duels - opinions wanted.
   / Getting ready to install duels - opinions wanted. #31
dcyrilc said:
You're probably right. Have you had a chance to check the fit/height of your tractor in the garage yet?
Not yet. The tight fit will be at our basement garage door which is currently framed in and is covered by siding. The basement garage by code is supposed to be enclosed in drywall so it is not yet being used as a garage.
Obed
It will be only a matter of time before you knock that door down. I know I would hit it in the first week.
Chris
Been pretty lucky so far. But then, I go in really slow too. I figure that eventually I'll get to add to the "dumbest things you've done with your tractor" thread.:laughing:
Obed
Makes sense. For some reason I was thinking that it was the 10 foot door on the upper garage which was walled off. Does that mean that you got the big door and had it installed already then? I seem to have missed that. I try not to miss any posts on your thread. Really going to miss it when your done with the house.:(
   / Getting ready to install duels - opinions wanted. #34
Cyril,
The 10' wide X 8' high door in our upper garage is installed. The basement garage door is walled off.
Obed
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
Chemical Containers Tank (A57148)
Chemical...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
2008 FORD F-350 SUPER DUTY (A58214)
2008 FORD F-350...
