Tires Getting ready to install duels - opinions wanted.
   / Getting ready to install duels - opinions wanted. #1
dcyrilc
Elite Member
Woodinville, Washington
John Deere 2240 MFWD
When I got my JD2240 last year it came with a set of duels but no bolts to attach them. I'm getting ready to order the bolts and put on the duels.
I have had two thoughts about doing this and was curious of what others thought of my ideas.
1) install both duels facing forward as normal,
2) install the duels backwards to increase traction when backing.
What are your thoughts on this?
   / Getting ready to install duels - opinions wanted. #2
I think duals on a tractor make the tractor look awesome. Putting the tires on backwards kind of dampens the effect.
Thanks for your thoughts. I keep swinging back and forth about which way I want to mount them. I kind of agree with you about the looks of having the duels backwards, but the idea of the extra traction when backing has merits also. That's why I thought I would throw this out for opinions.
   / Getting ready to install duels - opinions wanted. #4
I understand your reasoning. I do know how worthless tractor tires are going backwards. What you gain going backwards you will lose going forward.
   / Getting ready to install duels - opinions wanted. #5
Duals are generally used on bigger machines to lower the ground pressure so as to avoid excess soil compaction, and not so much for increased traction. The reason the European tractors have such wide tires is because they cannot travel over their narrow roads with American duals.
   / Getting ready to install duels - opinions wanted. #6
The added width of duals also give a tractor much added stability on traversing side hills.
   / Getting ready to install duels - opinions wanted. #8
Yeah, forward is better. :thumbsup:
   / Getting ready to install duels - opinions wanted. #9
when I worked at a cattle operation, (many moons ago, shoot many suns ago) we always put one outside tire on backwards, just for the reversing traction. But I agree they look better the other way. And I really don't know how much it was ever needed.
   / Getting ready to install duels - opinions wanted. #10
First, you need to decide if you bought the tractor to work efficiently...or look cool. Although a tractor can be both...you need to determine which has higher priority.
The only thing I've ever read was to reverse the front tires (on a MFWD machine, of course) to assist in backing out.
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
