Getting ready to install clutch
   / Getting ready to install clutch #1
LGP
OK the clutch is gone and I have to split the S630D in half.
First any suggestion were I can get this rebuilt and approx. cost.
Second are there any little tricks that I should know before I jump into this. I have manualls.
This is something that I have never done and I am not look forward to this but it has to be done.
/forums/images/graemlins/confused.gif
Your help is appricated
Larry P
   / Getting ready to install clutch #2
I can't help you much on your split. But here is what I did with my old Ford 8N split. Most tractors would be split the same way I believe. I used a jack stand under the tranny area with blocks and a few tapered wood shingles to get the proper height. Then a floor jack to support the backend of the motor and pulled it apart. I don't know if you can get a rebuilt clutch for your tractor. Do a www.google.com search for tractor parts or consult with your local dealer.
   / Getting ready to install clutch #3
I may have to split my Mits. 1450. Make sure you drive some wedges between the front axle and the frame on both sides. Otherwise the front will tilt over when you split the tractor. I think you block up the front half then put a floor jack under the rear for support and then you can roll the rear end back. Parts can be found, maybe locally at NAPA. I have bought some things there. If not check the mitsu club at yahoo. Bill Rogers or Len Shaefer can get what you need. If there is a rebuilder close by it will be a lot cheaper on the clutch disk. It don't hurt to ask. Don't put it back together without replacing the release bearing.
   / Getting ready to install clutch #4
I can supply a rebuilt clutch and pressure plate as well as the other parts you'll need. What you are attempting is not difficult if you take your time. But make sure the tractor halves are secure at all times. Its obvious, but bears repeating, you're dealing with very heavy parts. Be careful and have help nearby. Call 800-609-5110. Bill Rodgers - satohparts.com
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2023 JOHN DEERE 8R310 LOT NUMBER 188 (A53084)
2023 JOHN DEERE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
2025 CFG Industrial 680 (A50123)
2025 CFG...
