Getting my butt kicked power issue
   / Getting my butt kicked power issue #11
There is usually one fusible link and it’s normally a bigger one. You might not have one.
   / Getting my butt kicked power issue #12
The cable from the battery to the starter has to also supply power to the rest of the tractor. So somewheres there has to be an offshoot of the positive cable to another source. Can you trace entire hot cable. If there are no other wires off if battery positive post, there has to be additional wires off if the point the positive cable clamps to starter
   / Getting my butt kicked power issue #13
Where are the fusable links at? I feel like that maybe the problem, but dont know where to find them.
Usually near alternator or starter. Look for a ~ 12ga wire branching from the +Battery cable and probably going to the ignition switch. There will be an noticeable mystery bulge, or connector in the wire. That should be it. Only one.
   / Getting my butt kicked power issue #14
TRYING TO GET PAST SITE GLITCH - AI ru there?
   / Getting my butt kicked power issue #15
Are you able to locate a wiring diagram anywhere for this machine? I had a battery cable once look perfect, but it was all green and crusty inside the insulation and couldn't carry current. Same thing can happen with a ground, or any wire for that matter. Usually if they'll carry enough current to light a homemade incandescent headlamp / tail lamp bulb test lamp, the internal wire integrity is OK.
   / Getting my butt kicked power issue #16
I have no clue about your machine. The technique I use when I troubleshoot machinery for voltage is to fix the negative side meter lead to the negative side of the battery. I also prefer an anolog meter, I can detect variations easier. And if you keep checking and looking you should find a culprit. You have the good kind of problem, the difficult ones are the kind that come and go. Good luck
   / Getting my butt kicked power issue #17
“For a Bobcat CT230, the fusible link is typically located
near the starter motor. It is a slow-blow type of fuse taped directly into the main wiring harness.
Location details
  • Near the starter: The fusible link is positioned in the wiring that runs from the battery, protecting the starter circuit.
  • Wrapped in tape: Expect to find the link bundled with the wire harness, often concealed under a layer of electrical tape.
  • Inspecting the link: The link itself is a specialized piece of wire designed to melt under an excessive current load. If it has blown, the wire may look burned or feel brittle. “
Location details
I found the 60 amp slow blownfuse, but it had no power to it either.
I found a 60amp slow blow fuse, but it has nonpower to it either
Im still in the process of trying to trace that wire, but its a mess. 🤣
2008 TEREX TRAILER LIGHT TOWER (A58214)
2008 TEREX TRAILER...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
Kubota BX25D (A53317)
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
Dewalt DWM120 5" Deep Cut Variable Speed Band Saw (A59076)
Dewalt DWM120 5"...
12 ft Shipping Container (A55973)
12 ft Shipping...
