Oil & Fuel Getting air in injecter pump
   / Getting air in injecter pump #1
Fred wilson
NH 4270
Need some help. I seem to be getting air in my fuel. Idles great, throttle up and it starts fouling out, just had the injector pump rebuilt 30 hrs ago. Any ideas? New Holland 4270
   / Getting air in injecter pump #2
Make sure all the fuel delivery lines are tightened down properly and the filters are snugged down tight. Did you bleed the fuel system when you had it apart to install the injector pump?
all is tight , bled and dry, never a leak or even damp. think has somthing todo with the return from pump.
   / Getting air in injecter pump #4
got the fuel nines hooked up correctly, not backwards? Is the filter tight? Do you physically see the air in the lines, or is there maybe dirt in the tank, restricting the fuel flow...
There are plenty of causes for this.
   / Getting air in injecter pump #5
Check the fuel delivery. You might have some junk in the fuel tank restricting the strainer/tank valve and limiting fuel flow.
COLE 1R PLANTER (A52708)
COLE 1R PLANTER...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
BETTER BUILT FUEL CELL (A58214)
BETTER BUILT FUEL...
Mini Excavator (A55787)
Mini Excavator...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
