Getting a hole in the center.
   / Getting a hole in the center. #1
Rio_Grande
Platinum Member
I am trying to build a water wheel planter. To do so I need to build a wheel with sides on it running on a shaft. I have a air tank that will work diameter wise but it doesn't have nipples on the ends. It is convex in shape and welded on the edge. If it were flat I could get close with a square, but with the edges I am at a loss. It is too big to go in a lathe. Any help is appriciated.
   / Getting a hole in the center. #2
Get or build a big compass, big enough to reach 1/2 way across the end of your tank. Put the point on the outer edge and draw an arc in the center of the end. Without changing the setting on the compass, do this from 4 or more positions around the tank end. Now you can determine the center by all the different arcs you drew. Might not be perfect but close enough for farm equipment.
Another way would be to use a ruler and measure the distance all the way across, find 1/2 way and draw a short line. Do this again from the other direction. Where the lines cross will be somewhere pretty close to the center point of the tank. Again, not perfect but close enough.
   / Getting a hole in the center. #3
Lay it down on some wooden V blocks. Measure vertically from surface at v notch up to 1/2 across tank and mark. Turn tank and repeat etc. This should give you a very small circle of marks. Choose the middle of that.
larry
   / Getting a hole in the center. #4
If its a convex shape, and it's on a level section of ground, seems like you could find center with a square.
Sort of like this OL, if the O was one convex end of the tank the L shaped square would only be able to touch the center.
Thanks! It is amazing I couldn't figure this out myself. I can get it now!
   / Getting a hole in the center. #6
Just a thought? Have you considered utilizing a Chalk Line? Put the chalk line on at least four end points. The middle will be where the intersecting lines meet. Best wishes.
Yes, fella stopped in at the shop said same thing! Thanks.
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
24in pin on excavator tooth bucket (A56438)
24in pin on...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2010 CATERPILLAR 345DL EXCAVATOR (A60429)
2010 CATERPILLAR...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A56438)
2021 Takeuchi...
