Getting a Flashing code on a 2003 110 John Deere backhoe
   / Getting a Flashing code on a 2003 110 John Deere backhoe #1
LANGFORD
Burks Falls, Ontario, Canada
110 John Deere TLB
As the title says ,I am getting a flashing code that seem to indicate something wrong with the engine speed sensor. So I am getting loss of performance. Manual suggest :get single in range :cycle controller power to clear
Any thoughts how to do this.
Thanks
   / Getting a Flashing code on a 2003 110 John Deere backhoe #2
Any typo's in that suggestion from the manual?
And do you have the service technical manual or just the operator's manual?
   / Getting a Flashing code on a 2003 110 John Deere backhoe #3
what is the code sequence? maybe one of us could look it up for you.
   / Getting a Flashing code on a 2003 110 John Deere backhoe #4
OK It was suggested to disconnect the battery. I did for over a Hr the result is the flashing code stopped. Hope that will be the end of it.
   / Getting a Flashing code on a 2003 110 John Deere backhoe #6
Replace the flywheel sensor and your issue should go away. The original deere part number has changed but I believe I noted that in a thread on the issue. It isn't one of the ones Kenny linked so just search my username. I also included a pic of the sensor and its location.
Matt
2012 Cadillac CTS (A50324)
2012 Cadillac CTS...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
5-Bottom Plow (A52128)
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
