Gettin 6500 into 4wd
   / Gettin 6500 into 4wd #1
TooTall74
Is there something else I need to do besides pulling up on the lever by the fender?
thanks
   / Gettin 6500 into 4wd #2
thanks
Couple of things: I'm assuming you mean a Mahindra....2nd: Suggest you ask on the Mahindra forum (located under "Other Majors"). Now...yes you need to push in the clutch first, pull all the way up on the handle. To take it out you need to push in the clutch, push all the way down and then (I do this as I'm a Ford guy and am used to their 4WDs) back up about 5 to 10 feet to absolutely disengage....Don't run on asphalt/hard surface roads in 4WD. I seldom have to use mine as the weight of the tractor usually is enought to get the needed traction...BobG in VA
   / Gettin 6500 into 4wd #3
You know, now that I'm thinking about it, follow the Up/Down instructions on the label on the fender---tells you when its in or out of 4WD. But push in the clutch no matter what....BobG in VA
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
EZGO (A50324)
EZGO (A50324)
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
Panel Cart (A51695)
Panel Cart (A51695)
