LD1
Epic Contributor
Got the geothermal unit finally yesterday. Got things plumbed up and getting wiring now. Got some questions regarding heating DHW with the desuperheater.
I was thinking this unit hand an internal pump and temp sensor to know when to circulate the DHW through the unit to heat it. Found out it does not. Basically just a heat exchanger in the unit.
Talked to the tech and he said an additional pump is required to circulate from the hot water heater through the unit. And to tie it into the same contactor that controls the compressor and loop pumps. Ok, no big deal.
But What I am wanting is to do a two tank setup in series. Where the DSH heats a pre-heat tank that the incoming water supply is hooked to and that is what in turn fills the second tank that will have the heating elements. Goal is to keep the pre-heat tank nice and warm, that way when it fills the second tank, the elements have to do little at all. Only maintain. Everyone here showers in the evening, cooking, laundry, dishes, etc all typically done in the evening. I know a DSH is slow, but it will have nearly 24 hours to do its thing and catch back up.
My concerns are:
1. What about temp control? Dont want the first tank getting too hot and popping the T&P on occasion. The tech said as slow and as little heat as you get out of a DSH, that it just doesnt happen. Well, what if I leave the AC set to keep the house 70-75 in the summer and we go on vacation for a week?
2. Is a circulating pump even necessary? Or will convection (or whatever its called) be enough. Where the heated water naturally wants to rise, and in turn, returns to the top of the tank as it sucks cold water off the bottom?
Those with a 2-tank setup and DSH.....can you share (possibly some pics) of how yours is plumbed. Thanks
My concerns are:
