Flatheadyoungin
Veteran Member
i understand why you should put a crown on a road but should you put a crown even in sections where the road has a taper towards the drainage ditch?
One thing that has helped me in plowing snow.
I use a back blade and turn it around. That way it isn't cutting into the ground as aggressively. It does leave a bit of snow on the drive, but a day of sunshine usually melts the little that is left.
Hope that works for you.
I've been in contact with a US 200 geotextile fabric distributer. Their rolls are 432' long, 12.5' wide and $360 per roll+ tax.
Are there other brands I should consider? Is there a better quality product out there? I really don't want to cheap out on this. I have to live with it for the rest of my life and have 1200'+ to put in, so I want it right the first time.
I've calculated that I need about 300 ton of crusher run. Does this sound right at about 12.5' wide, 1000' long (give or take, probably closer to 1200' when I put some around the barn and make a turn around), 4" deep......
Any other advice? I've read most of the driveway threads on here but just want to make sure I don't over-look anything; drainage, culverts, crown, long sweeping curves, keep grade angle down, still keep the wooded drive looking nice, etc.....
I've spent some time on the dozer and it's coming together. If I can keep my pace and the weather holds out, I may be ready for aggregate in about 2 months.
Thanks!
thanks for the pics.....what direction does the driway point? does much sun hit it?
What makes you think you will need to use fabric at all ? I have put in several roads over the past 35 yrs. or so and only used fabric on one that bordered a wet land area and it has worked out fine. Another road was 1,200 ft. long with a graded red clay base and I put in crusher run 4" deep and added to it about every 5 yrs. or so but it packed like concrete. I grade it once a year with a box blade. Unless you have a really wet situation I for one do not see why you need the fabric especially if you put a crown on the road and keep in mind since you are going through the woods and your road will be tree lined , any roots you are digging up putting in the new road will likely cause the trees nearest the road to die in time so you may want to use caution how deeply you set your bucket or blade as you grade..
