wcampbell47
Platinum Member
- Joined
- Jul 21, 2009
- Messages
- 721
- Location
- Texas Coast
- Tractor
- Kubota L3901 ASV Compact Tracked Loader
My air compressor has been wired for 220 for years simply because 220 is more powerful than 110 and draws half the amps. The air compressor is old and has leaks so it leaks down between usage. My generator will power it up the first time and run it until it reaches full pressure. After that forget it. Gasoline powered compressors have a relief system that opens and allows the gas motor to keep running when tank pressure is reached. I think switching to that type of relief system where the electric motor always runs might cure my issue. I have a very similar issue going on with my RV generator and roof top A/C. As long as I keep the temperature set at max the generator will pull the A/C. If the A/C cycles off and on again the generator stalls.
