Generator switch broken. Now what?
   / Generator switch broken. Now what? #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
I have a little Harbor Freight 11HP generator - the "US General Thunderbolt model 5708", made by McColloch (Harbor Freight Tools - Quality Tools at the Lowest Prices. My framer has been using it for power on the new home construction site and one of his guys evidently broke it - I found the on/off switch sheared from the base this evening. I am going to be calling McColloch tomorrow to see about getting a replacement, but does anyone know how these switches work? In other words, is there a way to bypass this switch for now to allow the continued use of the generator?
   / Generator switch broken. Now what? #2
Those on/off switches are usually a ground. When you turn it off, it CLOSES the switch to ground the stator? ie no spark.
but its one of 2 things. either it closes the ground circut, or it open's the spark circut. either way its easy to bypass and or wire in a simple toggle switch to do the same thing.
   / Generator switch broken. Now what? #3
Just take one of the wires off the switch and try to start it. It should run but you would have to touch the wire back on the switch or to a metal part of the generator (depending on which wire you removed) to stop it. Or if you have to, put the choke on to kill it.
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
434669 (A48836)
434669 (A48836)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
