Generator shot down procedure
   / Generator shot down procedure #1
alexinPA
NE PA (Lackawaxen)
Kubota B7800
Do you guys turn off fuel line to let engine to shot down? I know it's recommended for other equipment before long storage. What
about a generator since it's being run often as part of maintenance?
   / Generator shot down procedure #2
I quit running my small engines dry years ago. Seasonal and infrequently used engines get the fuel treated with Stabil run through the fuel system.
   / Generator shot down procedure #4
Yes. I disconnect power then shut off the fuel. As it surges lean, I partially engage the choke, till it’s run dry. I never use the kill switch. Starts first ir second pull every time. Sometimes not run for 6-12 months. Been doing it with this particular generator for about 20 years. Still runs like new.
I do this with all my small 4-stroke engines that have a fuel shutoff. They definitely start and run better since I started doing it
   / Generator shot down procedure #5
Run all my generators dry. Drain gas tanks in March, run until carb empty and let them set till early December. The lone exception is a suitcase generator I keep in truck for farm use that has gas in tank and carb year round with double shot of seafoam in tank
   / Generator shot down procedure #7
run dry, only way you don't need to do anything for years and they start right back up
   / Generator shot down procedure #8
I just shut mine down with the kill switch. The same with all my gas stuff (2 and 4 cycle), I never drain or run dry and I haven't had any issues for over 25 years.
   / Generator shot down procedure #10
Donno; never seen a generator "shot down".
1988 John Deere 410C 2WD 24" Backhoe (A49251)
1988 John Deere...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2018 GMC SAVANA 3500 16FT BOX TRUCK (A45679)
2018 GMC SAVANA...
Heavy Duty Plate Compactor (A47371)
Heavy Duty Plate...
2011 International WorkStar 7400 Truck, VIN # 1HTWGAAR2BJ325810 (A48836)
2011 International...
Engine & Transmission (A49251)
Engine &...
