Generator Motor runs sloppy
   / Generator Motor runs sloppy #1
R134a
Mahindra 2538
I have a Briggs 01679 standby generator using a 570 v-twin motor # 354447 0122-e1. Speed wanders and sometimes backfires. This runs on propane. Anyone have a service manual / parts list for the fuel system ?:confused2:
   / Generator Motor runs sloppy #2
I think my ex GFs mother has one of those. When I was there in the spring, it was out of service and has a speed control issue. Start, rev up and then would shut down, showing overspeed.
Curious if they have some common issue.
Doesn't stall. I'm thinking deteriorated carburator gasket(s) + ??? Documentation might save me some grief. Unit is likely 15 yrs old or more.
   / Generator Motor runs sloppy #4
Could be bad ignition or an air leak causing too lean condition. I'd start with a new spark plug and check the carb manifold gasket by squirting oil on it while running.
spark plugs and coils are fine. I'm going to take the carb off and take a look at everything. No doubt the gaskets are likely dry rotted.
   / Generator Motor runs sloppy #6
It's not like it's a gasoline related issue. What governs speed on those?
Toro Z Master Mower (A50324)
Toro Z Master...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2005 OTTAWA T2 YARD SPOTTER (A51222)
2005 OTTAWA T2...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
