Generator light
   / Generator light #1
japody
Platinum Member
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
This is a weird one. Replaced the battery on my '69 5000 yesterday. Now the gen light gets brighter the more I rev the engine. Shouldn't it be the other way around. Any thoughts, ideas on how to fix? Thanks in advance.
   / Generator light #2
I like to never found this up in the NH section. ;)
Ok, where I left off from private mail.
Have you repolarized the generator?
Bat to field and armature. ( pull arm and field wire off he, from reg, when you do this )
If that doesn't help,
When you turn key on, do you get oil and charge lamp on?
( check fuse at harness behind cluster )
If still no, motor test Gen.
Same as polarizing, almost.
Loose Gen, slip belt off, retighten brackets, need good ground. Apply bat hot to armature..might spin weekly. Apply bat hot to arm and field, should spin real good, like an electric motor. If not, it needs a trip to the doctor.
If yes, try one more thing.
Get belt back on, start her up, get rpms mid throttle. Still red lamp? Yes, put meter across battery. 12.6 is nominal, 13.2-14.x is charging.. Lower rpms charge lower on a dc generator.
Now.. Is it showing 13+?
If not remove field wire and jump Gen field to bat hot. Meter should show good charge. If not, and he passed motor test, next jump arm to bat hot, if this shows charge, your prince of darkness vreg needs looking at. Sometimes you can pull the cover and clean them up, other times.. Replace as needed.
   / Generator light
I won't be able to get to the tractor for a few days. Will test as you have outlined and report back with findings. Thanks for the directions.
   / Generator light
It was the generator. Will be replacing with an alternator. Thanks for the help.
   / Generator light #5
good deal... it will work.
   / Generator light
Thanks for the guidance. It was spot on.
20305 (A51694)
20305 (A51694)
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2005 FORD F-650 (A52472)
2005 FORD F-650...
