Generator Damage Electronics?
   / Generator Damage Electronics?
..............................What kind of printer?.......
I was thinking of an ink jet
Different UPS output different types of power. Most put out pseudo sine waves, kinda like a square/saw tooth wave. I have another UPS that puts out a pure sinewave, needed for fish tank pumps.
I wondered how true the wave form was on the UPS units. Thinking back to my original concern of protecting a high efficiency furnace's electronics, would a UPS be a practical device to have in series with a furnace?
I seem to recall a guy that was emergency powering his house by feeding the 240v DC of his Prius traction battery to a large UPS unit. If I recall correctly, his furnace didn't like UPS power and he had to build a special circuit to make the furnace work properly.
   / Generator Damage Electronics? #32
Bob,
Its not the items you mention that cause problems running on a generator since they don't draw a lot of current. What causes problems is when a high current device such as a 220V well pump, freezer compressor, refrigerator compressor, or A/C unit come on they create a large current draw on a generator. A compressor from fridge/freezer/AC can initially pull over 20A on start up. Add that to the load the generator is already supplying and it causes an overload for a 4K unit. If the generator is not large enough to handle that load the output voltage drops below where it should be which is what you saw as major dimming of lights and TV picture shrinkage. Had your freezer or fridge started as the same time you would have probably tripped the 20A breaker on your Generator.
I do run the refrigerator, 220 volt well, septic tank pump, etc. on the generator. The lights got real dim when the well started on the 5KW gen. I also have an 8KW gen that I usually use when I run the well. I have a large water tank so I can sometimes go many hours without the well. The items I mentioned were to indicate the things that might be damaged by the high current motor items. I don't suggest that you risk your devices.
Oh, I also have surge suppressors on my panels which will clamp spikes. You might get spikes or surges (which are longer term voltage rises) when the motor items cut off and unload the generator. That may be the problem and not the sags or drops. I am not sure why the sags would damage the electronics. I can't explain it and I know quite a bit about electronics, but not everything.
Just to clarify, the surge suppressors are ones that mount in the circuit breaker panel and clamp at 500 volts, not the 1000 volts or so that most use. I had to special order these from Cutler Hammer.
   / Generator Damage Electronics? #33
I agree with the whole house unit. I have a computer that runs my pump on my well called an Aquavar system. The utility company spiked and blew my unit 3k work.
I put a line conditioner on before the computer FROM the utility company tp protect the computer and before pump to protect the well. No problems since.
Fro in house units look at these.
UPS power protection, surge protector ? Powerware 5110 UPS
The Powerware 5110 uninterruptible power system (UPS) was designed to provide the best UPS power protection against the threats that lurk in public utilities. This line-interactive UPS system delivers the ultimate in power quality, constantly safeguarding your equipment from power outages, surges, sags, brownouts, and over-voltage conditions謡hile also providing varying degrees of power management for additional threats. If utility power is interrupted, even briefly, the Powerware 5110 transfers to UPS battery power.
Features & Benefits
Protects the integrity of your data and applications by shielding electronic equipment from power outages, surges, sags, brownouts, and over-voltage conditions
Saves space with a compact design that can be deployed as a tower or under a computer monitor
Protects loads on eight outlets - four with surge suppression and battery backup, four with surge suppression only
Delivers consistent, clean output with Automatic Voltage Regulation (AVR) that doesn稚 drain battery power
   / Generator Damage Electronics? #34
We now have three APC UPSes in the house. Each desktop has its own UPS. I replaced the bad battery in a very old UPS I had laying around and our router and DSL modem are plugged into it.
The old UPS beeps when we have a power twitch. Almost every morning around 5:00-6:00 it beeps. I suspect people are getting up and drawing more power or the power company is preparing for same.
We need a another UPS for the stereo. If we loose power it drop some of its setup. Not real impressed.
I wish we could put in a whole house UPS but I don't think I could afford it. :D
Later,
Dan
There is another thing some of APC ups'es to a selftest were they switch to battery and check battery and switch back.
tom
   / Generator Damage Electronics? #35
i have a small APC ups on my satellite receiver and another on my computer: strickly to stop the quick on an offs that we seem to get a lot of: but i do have time to shut down the computer when the power goes off an stays off: if i'm home...i got tired of the satellite receiver shutting off and having to reboot when the power would flicker.
heehaw
   / Generator Damage Electronics? #36
IMHO.. the issue was with a 4k genny having too much load at furnace startup.. and then there was a peak right after the load dropped off.
cycles wouldn't have mattered to the wallwart.. either that.. or the modem just picke dthen to die.. remember.. it's onthe phone line.. why was power out?
I've had inet modems die for no reason... just happens to somethings..
if you didn't have a whole lot of electrical failures at the same time.. i'd call it an isolated incedent..
soundguy
Right
Tree fell on electrical lines, but phone / cable lines were not torn down.
if you didn't have a whole lot of electrical failures at the same time.. i'd call it an isolated incident..
soundguy
Thanks, Soundguy. You may well be right. I just wanted to make sure I learned something by this minor incident in case it was a warning about more expensive problems in the future (i.e. hi efficiency furnace electronics)
   / Generator Damage Electronics? #38
I run expensive electronics of fmy pto genset.. never had a failure I could even remotely attribute to a power issue. ( don't recall having -any- failures while on generated power ).. However I have plenty of failures I KNOW came from grid power... had browns that killed stuff.. had peaks where lotsa lamps got bright for a second and then one or two died... that was a truly weird one... thought a ufo was landing or something.
soundguy
   / Generator Damage Electronics? #39
Had a real surge go through the house several years ago. A high voltage feeder line crosses over my entrance line, on a cold Feb night it snapped and dropped across the entrance. Lineman told me my line was hit with 3 surges at 45,000 volts before fuses at sub-station cut out. Lost fridge, microwave and computer, Utility Co wold not go replacement cost prorated everything.
Thank goodness had wood heat,as it was about -20 that night!
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
378813 (A51573)
378813 (A51573)
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
