Generator brands
   / Generator brands #51
Was At Rural King today and say they have the Champion inverter genset..... 549.00 humm a pair of these right at a grand might give you the low cost, low noise etc. If you do try these let us know how they work out ..
If I was in the market I would really give these a hard look.....I love my hondas and only paid 800 each when I bought mine but they are more now.
   / Generator brands
Yea the wallet will end up making my decision for me I feel. I have not ruled out the Champion. I also FULLY understand that the unit would not be at 1/4 power to operate the AC but they have to have some standard for rating noise. According to the Honda web site, their 3000 puts out 48db at 1/4 power and the Champion was much more that 1db higher. On sales web sites they show a range of 48-59db IIRC for the Honda and I take that to mean idle to full load levels. The Champion was only rated at 1/4.
I agree on the theft issue, not something to leave sitting around when you leave camp.
On the parallel 2000's, how does that work? Although I do think that elec start will be a necessity, since it will be elevated and the rope pull will not be easily accessed. The pull start only was my big concern with the Champion.
   / Generator brands #53
Chris - non-boater here.... what do you recommend for quick connect fuel couplings for external tanks ?
(handirifle - apologies for drift.... )
Rgds, D.
Use marine grade outboard external tank type. Avaliable online, any marina, some Walmart Stores, and even my Menards.
Chris
   / Generator brands #54
I have a cheapo Coleman 4000 watt generator that I stuck a car muffler onto. The muffler knocked out most of the exhaust noise, but it is still quite loud. All those fins designed to radiate heat also radiate mechanical noise nicely.
My findings putting well over 50 generators onto house boats and campers is it the generator itself that is loud, not the exhaust so much.
Chris
   / Generator brands #55
They sell a cable kit to connect the eu200's together then a single 30 am plug i made my own with two male 20 amp plugs Y'd to a single rv 30 amp. since Im the only one running my gensets I understand the risk of the live plug.
   / Generator brands #56
We had a Champion 3000 watt generator on our moose hunting trip and it fried one of the boards in my new Jayco toy hauler. We now use a Honda EU3000.
   / Generator brands #57
Chris
Thanks Chris - I remember the quick connect setup from friend's boats years ago.... was expecting it to be still standardized, but wanted to ask - I know to stay away from something labelled "Bowter Aproved", but not much more about current fueling standards :D.
I'll drop by a West Marine. For the application I have in mind, I'd like to Y in the original tank on the generator as I don't always want an extended run with that gen.
Rgds, D.
   / Generator brands #58
Aside from the parallel cable kit, what makes this work is that some inverter class generators have enough "smarts" built in to sync with one of it's twin models. To be clear - you don't want to try paralleling with any generator unless the manufacturer explicitly states that it is designed for that purpose. Getting that wrong would be dangerous and expensive.
Sounds like electric-start is a must have, if you are locked into that location.
Rgds, D.
   / Generator brands #59
That makes sense. Some people have had good luck with portable sound baffles (think folding screen), to redirect the remaining (or even primary) sound. After I upgrade the exhaust on mine, I may build a vertical screen baffle to try.
Rgds, D.
   / Generator brands
Rgds, D.
Dave
I kinda figured that on the sincing of the generators, but ws really wondering how they sinc'd the sine waves. Bet that's tricky.
Chris' findings are interesting as well, especially since so many pointed out that when they silenced the exhaust, there was still a lot of mechanical noise left.
As for location of the generator, most of the 3kw units I see are over 100lbs and while I could probably get it to the ground from a carrying rack behind my 5th wheel, I might "rip" something thing to get it back in there, and my wife would be of no help in that respect. So short of setting up some hydraulic lift (not gonna happen) it would get mounted there.
Unless someone here has an idea that could be implemented fairly easy. I was just discussing with my wife, the fact that we would want to use it as an emergency unit for our home, but not sure how to get it down from the trailer. I could tow a small fork lift along with it I suppose :thumbsup:
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
UNKNOWN 16 T/A UTILITY TRAILER (A50854)
UNKNOWN 16 T/A...
