Oil & Fuel General question about stuck oil pan plugs
   / General question about stuck oil pan plugs #1
richdeming
I know this is a general-mechanic question, but:
I went to change the oil today on the TS 1610 . The oil pan plug is on there very tight. I tried everything I know but I'm afraid I'm going to ruin the head. Anybody have any good suggestions for getting it off?
Thanks a bunch, Rich
   / General question about stuck oil pan plugs #2
when you do get it off, might not be a good idea to reuse it.. I've seen alot of stretched threads on drain plugs over the years..
They usually will come off, but I have run into a couple that were crossed...:mad: but not many in 25 years..
drain plugs are fairly cheap..oil pans not so cheap..
   / General question about stuck oil pan plugs #3
When I have had that problem, I first procure a new plug. Then take a pipe wrench and use it to take the plug out. Be sure to check the pan threads before putting the new plug in. If the new plug doesn't go in easy, chase the threads before damaging the new plug.
   / General question about stuck oil pan plugs #4
Good advice from both irwin and JerryG.
   / General question about stuck oil pan plugs #6
a six point socket.
   / General question about stuck oil pan plugs #7
Jimbrown said:
a six point socket.
In conjunction with an impact wrench.
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
198367 (A51243)
198367 (A51243)
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
Toro Workman Utility Cart (A51694)
Toro Workman...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
2008 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2008 Jordair...
