General purpase chain size
/ General purpase chain size #21
Lowes Home Improvement sells a grade 70 5/16" chain 20 ft long with grab hooks each end for $36.98 today. I bought 4 of these back in 2005 to tie down my 110tlb for transporting. At that time these were $29.99 each. No problems in 12 years of use.
Good for small utility tractors and large CUTS.
/ General purpase chain size #23
AND it's made in the USA!:united-states:
/ General purpase chain size #24
Got my supply of 5/16 chain hanging off the front bucket on the Kubota. Great for rigging all sort of stuff. Got a five gallon bucket of 3 /8 chain I used when younger. Now the pail rides in the bucket because it is heavy to carry.
/ General purpase chain size #25
I had "decided" I was going to standardize on 5/16", but then I picked up a 10' piece of 1/4" G70 (3150lb WLL).
The 1/4" seems like a nice size, but it's actually more expensive than the (more common?) 5/16".
if you work with a chain frequently the 1/4" is easier to handle. Plenty for the bx use too. You may find a short chain 2' to 5' with a slip hook x grab hook will be handy to have too. I use these short chains to pick up implements and other objects with the fel and backhoe. The slip hook will fit over the bucket lips where the grab hooks will not.
/ General purpase chain size #27
1/4 chain is so small I worry about it being physically damaged. Not necessarily exceeding the wll but nicks or damage to the links. There just isn’t much metal there. For some things it may be fine. I use 1/4 chain to tie down my UTVs but wouldn’t feel comfortable with it for general purposes as hard as I am on things
/ General purpase chain size #28
I use mostly 5/16 grade 70 chain with grade 80 hooks but I have a few 3/8 chains. My long chains all have grab hooks on them. I have short chains with just a slip hook or whatever on one end and I use those at the end of the long chain with grab hooks. I like the twist lock hook as well.
/ General purpase chain size #29
I mostly run 5/16th" G70, with a 3/8th" here and there. My "I wasn't asking" size is a 7/8th" cable. Scraped out for the application it was in(crane), but way overkill for my needs.
I do have one of those bunch grubber things coming to deal with some briars I can't dig up with the ratchet rake due to them being underneath bushes I want to keep.
/ General purpase chain size #30
Sounds familiar! Only my five gallon pail full of 3/8" chain sits far back in a corner of my pole building. :laughing:
/ General purpase chain size #31
I use 5/16" grade 70 chain because it not too heavy yet not too light. Still, a 10 or 20' piece is a handful. Now, hold that thought.
Years back I got a piece of 1/4" (9/32?) alloy logging chain and over time have used it for some pretty nasty stuff without any issues. It's light, easy to handle and I've since learned it has a higher breaking strength than grade 70, 5/16 chain. So, why not high strength 1/4 (or 9/32?) for most of our applications? As well, a lot of "farm" use chain is really only grade 30 and in that case 1/4 (9/32?) heat treated chain is vastly superior to 5/16 chain.
One thing is you would need to make sure the hooks are rated the same as the chain and compatible with 5/16 chain in case you need to hook to that commonly used size. Or, just be content with 1/4 (9/32?).
/ General purpase chain size #32
I was leary about using the 1/4 inch chokers that came with my winch; especially since the 5/16 that I made up years ago look like pretzels. The new ones have worked out well so far though and most likely are better quality steel; because they are lighter it sure was easier carrying them through knee deep snow this past winter.
/ General purpase chain size #34
1/4" is fine for a BX lifting on the loader, or gentle pulls. But I'd stay with grade 43 or 70. But really there isnt alot of weight difference between 1/4 and 5/16.
If you do get 1/4" go easy on pulls. While you might not weigh much, or have alot of traction, its easy to get some extreme shockloading and snap a chain if you try to "bump" or jerk a load.
This.
I have a bunch of G70 3/8 transport chain I normally use for stuff. Put some 1/4" on the tractor to move a stump I thought was already loose, and when it caught it elongated all the links of the chain being pulled with my NX and stopped it.
Chain breaks are bad. If you're yanking on something use the best you have. For lifting on the loader, sure 1/4" is great. I have a few pieces made from 1/4" just for that reason.
