pclausen
Veteran Member
As I'm preparing to install a new 20KW generator at my mothers, I picked up the failed 15KW unit and took it home to tear down the engine in the hopes that I can fix it.
As per the other thread (Which 20KW whole house generator would you choose and why), the Generac tech that came out said the engine passed compression test fine, but that cylinder #1 had a 28% leak down and #2 had 48% leak down. 28% the cut off Generac uses to replace engines under warranty. The tech said the air appears to be escaping from the oil dip stick hole (dip stick removed). So that would likely indicate an issue with the pistons and/or rings.
I started by removing the top and front covers. This whole genset looks very clean:
Close up showing the model number:
Here it is after removing the muffler, control board and "firewall":
Shrouds, intake manifolds and air box removed:
#1 valve cover removed. Top of valve train looks ok.
#1 piston:
#1 cylinder wall. You can still make out the honing marks:
#2 piston:
#2 cylinder wall. Again, you can readily make out the honing cross pattern:
#1 head on left, #2 on right:
Closeup of #1 exhaust valve. Any idea what that white buildup is?
#1 exhaust valve stem. Whatever that buildup is, it doesn't look good.
The head gaskets looked fine. I don't see any obvious signs that the piston rings are shot and causing leak by, yet the leak down test seemed to point in that direction. Could the exhaust valves be the only culprit here?
I'm wondering if I should continue with tearing down the bottom end, or fix the heads first and see if that fixes things?
From what I'm seeing so far, I would say the odds are good that I can get this engine running well again. What do you guys think?
#1 piston:
#2 piston:
