Gearbox for Farm Force rotary cutter
   / Gearbox for Farm Force rotary cutter #1
kempersw
Ford 3000
I have a 5' farm force rotary cutter, the housing on the gearbox broke. After dismanteling I found the bearing destroyed and wear on the gears. Anyone know where I can get a replacement gearbox?
   / Gearbox for Farm Force rotary cutter #2
Check Agri -supply- they have a 40hp gear box that may fit- cost is 99.00. the bolt hole pattern is listed and it also lists as a King Kutter replacement. It has 2 different models, one with a six spline input shaft or a smooth shaft with shear pin. The output shaft is 12 spine tapered.
I just picked up a older model Woods rotary cutter that needs a gear box as well. I plan on purchasing this gear box and modifying the deck to accept the bolt pattern.
Thanks, that looks like it'll work, I just have to check the bolt pattern
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2013 John Deere 824K (A52748)
2013 John Deere...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
Whiteman 6' Ride On Concrete Trowel (A47384)
Whiteman 6' Ride...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
