Gearbox/axle oil seal
   / Gearbox/axle oil seal #1
marthaiseki
Lewes England
Kioti CK35 TYM 237
I'm getting a bit of a drip from the right hand side rear axle where it joins the transmission box. I guess the oil seal needs replacing.
Do you have to remove the side plate from the transmission case to then get the axle out to replace this seal or is there an easier way?
   / Gearbox/axle oil seal #2
I Had the right rear wheel seal replaced on my TYM 433 and they hade to remove tire and wheel disassemble right side rear axle and replaced a new internal nut and gasket and new seal ended up costing me over $800.00 dollars for this repair also the fluids refilled and filter changed
Not a cheap repair also they found small metal shaving in oil and a metal pin in oil ... they wasent sure of where this was from but they said the could fix it but it would be around $7000.00 dollars to fix and 2 weeks to do the job
   / Gearbox/axle oil seal #3
Sounds like they plan on making a goods weeks pay. Not knowing what they are looking for but know it will be expensive.
I just bought a used Mahindra 2565 cab shuttle. The only thing that is not TYM is the engine and the front grill emblem. I have been buying things to make it 100% and I find the prices through my Mahindra dealer to be quite high. Probably true with any of these compact tractors.
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
