Gear Whine
   / Gear Whine #1
atk_man
Duncan, BC, Canada
1979 Kubota B7100D
Will I ever get used to the Gear Whine and other noises that my 79 B7100 makes?
Driving my deisel truck all day then hopping on the tractor gets tough.
   / Gear Whine #2
Yep..after a while you'll hardly notice the sounds,if not ear plugs /w3tcompact/icons/frown.gif
   / Gear Whine #3
Ear Plugs and ear muffs do wonders for silencing all the different noises.
Like Thomas says they are a little mule.
Mine has all the loader pins worn so everything can be shaken by hand. In fact the lower two on the bucket actually wore out and had to be replaced but with a bolt and nylon lock nut. The loader frame and bucket have numerous welds on them from digging out rocks and tree stumps. The bucket cutting edge is wore out and needs replacement. I've also had it standing up at about 45 degrees trying to shove a tree over. It's pulled numerous rocks by filling the bucket with rocks and then putting as much lift on the three point as possible to get traction. 1600 hours and does not use any oil. My only complaint is the hydro pedal not centering properly anymore.
It has served me well.
Egon
New Holland C345 (A50120)
New Holland C345...
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2013 F-550 Bucket Truck (A52748)
2013 F-550 Bucket...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2007 MACK CT713 ROLL OFF TRUCK (A52141)
2007 MACK CT713...
