Gear shift stuck in low gear?
   / Gear shift stuck in low gear? #1
JLF
Chase City VA
Ls G3038
I was doing some light plowing yesterday and when I got finished for some reason my gearshift seems to be stuck in first gear I cannot move it out into second third or fourth does anyone have any idea why this may be stuck? The 4WD, Shuttle Lever and Range Gear Lever all seem to work fine, it's just the Main Gear Shift Lever that is stuck/won't shift?
Any ideas? I hope like **** I didn't overwork the transmission while plowing!!
   / Gear shift stuck in low gear? #2
Anybody out there with a solution to this? I have the exact same problem...
Please...???
   / Gear shift stuck in low gear? #3
Take the tractor out of 4WD. Do this on a slight incline. Let the tractor roll backwards ten feet or so. Now try shifting......
   / Gear shift stuck in low gear? #4
Yep. Move it back and fourth, forward and reverse. Gotta take the pressure off the gears. It should pop out. Happened to be once while I was on a steep incline. I just backed up a bit and it popped out. Nothing to worry about... unless this doesnt work.
   / Gear shift stuck in low gear? #5
On my M4700 it's gotten "stuck" twice. Both times I had to get under it and apply a sharp but light quick force administered by a small hammer against the gear linkages.
   / Gear shift stuck in low gear? #6
JLF - What's your status? Were you able to get it out of first gear???
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2013 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2013 Freightliner...
Komatsu WA3801-7 (A50120)
Komatsu WA3801-7...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Smoke Daddy Portable Grill (A50515)
Smoke Daddy...
CFG Industrial MX12RX (A50121)
CFG Industrial...
