Gear ratios of a model L 6.5
   / Gear ratios of a model L 6.5 #1
mx842
Platinum Member
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
Does anyone know what the gear reduction is at the PTO on a model L? I've looked far and wide but can't find it anywhere. Thanks!!!
   / Gear ratios of a model L 6.5 #2
Hi They are four L model. Ls-LI-L- L8 They have Two PTO speed.
IN High Gear from ( 682 PTO rpm ) at 1364 engine rpm speed to ( 1364 PTO RPM )at 2728 engine rpm speed
IN Low Gear from (341 PTO rpm ) at 946 engine rpm speed to (1023 PTO rpm ) at 2838 engine rpm speed
Good luck! Oldmech
   / Gear ratios of a model L 6.5 #3
HI! For PTO L model . The PTO ratios are about 2 to one in High speed and about 3 to one in Low speed. Good luck! Oldmech
Thanks......That's exactly what I needed to know. Also, I didn't even think about the high and low lever having any effect on the PTO output that's good to know also.
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Engel 20' Boat (A50121)
Engel 20' Boat...
Hyster H225E (A47384)
